When using jbrady3324's PZ80U ISF settings I noticed the following:
1. If you copy all settings exactly including "SM after" except for ALL-CUT and ALL-DRV, you get pretty good PQ except for noticable red push.
2. If you apply ALL settings using the offset method, you get great PQ with less red push.
3. If you copy all settings exactly including "SM after," setting ALL-CUT and ALL-DRV last, you get excellent PQ with minimal red push and what appears to be a perfect graycale to the eye. It's important to note that when you set ALL-CUT and ALL-DRV exactly to his settings after doing the same for the individual RGB cuts and drives, it changes some of the individual RGB values automatically to better suit your TV. I'm guessing this is some sort of mechanism designed to protect the neutrality of your white balance when individual values stray too far apart/ too far off for your set.
