Originally Posted by
LBFilmGuy
Can anyone with a PZ80 that has changed their service menu settings please post their before and afters? Also your user settings to go along with them.
Just want to try a few different ones...thanks.
Use the AVSHD709 Disc to adjust brightness, color, and tint. You can do it first in the SM and then tweak in the UM or do it entirely it the UM. For contrast, use 000 in the SM and try 50 in the UM. Sharpness should be left at 50 and is only present in the UM.
For grayscale, note that I've copied JBrady's after settings but the top three values with an asterisk are two units higher since when I copied his after settings directly, my ALL-CUT went to 7E (two units below 80).
Try the following:
User Menu:
Cinema
pic: 50 fixed
bright: set 2nd
color: set 2nd
tint: set 2nd
sharp: 50 fixed
temp: warm
color management: off
Adjust
000 fixed
XX set 1st
XX set 1st
XXX set 1st
WB Adjust
7D*
80*
7B*
E4
FC
A0
80
FC
I set my brightness to 7FD in the SM and didn't have to change it from the default 58 in the UM. I'm awaiting THX glasses so I can set color and tint.
