Originally Posted by
bodosom
The PZ only supports two point grayscale adjustment. Ten is considered adequate. Twenty is good.
Understood and I agree.
bodosom
Negligible unless your display has a visible tint. "Red push" (whatever that's meaning at the moment) is a defect in displaying the color red, it does not mean that shades of gray look like shades of red. The PZ also tends to have green out of gamut (which makes grass look "better"). That is also unrelated to the grayscale adjustment.
I got my meter out and decided to give the Curt Palme calibration guide for dummies and colorHCFR a go. The grayscale showed a rather constant red at about 110% across all intensities. Green was also very constant at about 97%. Blue was a bit more in sawtooth pattern between 97 and 105%.
I decided to adjust the red and green drives and cuts to bring both to around 100% and tried to adjust what I can on the blue. What I thought was described by "red push" was simply too high red values in general on my tv.
Measuring the primaries I saw that the blue is very close to target, red is a little beyond the red target and the green is beyond green target and going towards blue. So is that "redder than red" primary what is described as the "red push"?
I noticed that I would need to use very different values of tint to get all values on target. Yellow needs +9, cyan -7 and magenta -10. I don't know what to think about this. I'm trying to find a tint value that minimizes the error for all three; should I instead favor one?
My new user menu settings after the calibration produce a 40 ft/L 100 IRE window and go like this:
Mode: Cinema
Picture: +55
Brightness: +52
Color: +42
Tint: -3
Color Temp: Warm
The overall result is a color temperature closer to 6500K than it was and a notable improvement in general, even more so on skin color rendition. The improvement was worth every second spent reading this thread and Bodosom's links. I benefited from everyone's contribution and am very grateful for this. And special thanks to Bodosom. I will be happy to further improve my settings but now feel that they would be subtle. I have nothing wrong with that!
