What color is yours?
post #1 of 25
Walls, ceiling, carpet, bar, and trim? We are at the point of making these decisions and need help.
post #2 of 25
front wall and ceiling = behr mickey mouse ears flat black.
side walls and rear = behr vin rouge aka wine red.
trim is maple stained with mahagony stain.
carpet is garden path by shaw = a dark greenish brown.
seating is dark sort of reddish brown.
see signature link for details.
later.
post #3 of 25
A somewhat downscale theater by design:
Walls and cieling = Black rubber like material
Carpet - Grey-ish (well it was called cobweb anyways)
Trim - unfinished pine which I still have not completed, not much incentive once your functional in a down scale theater.
Bar / Consession counter is black - Carpet in the area is Moon, Sun, and Stars
post #4 of 25
My main paint color was Behr Orchid other than that ceiling is a mixed midnight blue looks very black then my wall treatments are red, black and navy velvet.
See signature for link to my theater thread.
post #5 of 25
post #6 of 25
Benjamin moore metallic gold trims, satin black walls and ceiling,minwax red oak on cherry, Burgundy theater seats, red leather sectional and charcoal theater theme carpet.
http://picasaweb.google.com/mahler007/TheatreRoom
post #7 of 25
Don't be so quick to go "flat black". Look for a (flat) dark color that fits within your overall color scheme. When the lights are down it will be as effective as flat black, and when the lights are up it will look a lot better.
post #8 of 25
look at my link - i'm using flat black for the projector area. I just painted one of the basemetn pillars venetian red - it looks sexy as hell to me.
I'm gonna do the walls gray suede (ralph lauren) - I thikn it will look good even though my carpet is already light gray (argh).
post #9 of 25
Front wall and ceiling: Flat Black
Upper Walls: Forest Green
Lower Walls: Stewart Plaid
Carpet: Forest Green
Trim/Chairs: Black
post #10 of 25
Front walls and ceiling: flat black
First few feet of side walls (connected to the front wall): flat black
Other Walls: Flat Gunmetal Gray
Trim: Black
Carpet: Black industrial with gray
Couch: Black faux suede couch cover
Curtains: black faux suede
yeah, its pretty much a black hole in there with the door closed.
post #11 of 25
How about outlets, what did yous do about them? I also have inwalls speakers that are paintable, Do I paint to match the walls, outlets, leave them white, or off color them?
post #12 of 25
My outlets and wall covers are also black. They arent painted to match so they are a bit glossy, they are just the ones from Lowes. A contrast could be cool, depending on the wall color. I was just going for the black hole look.
post #13 of 25
I wouldn't leave them white. I'd either have them match the wall color or the trim color (which also shouldn't be white).
post #14 of 25
It has been decided! Red Carpet inset in a dark hardwood. Black front and ceiling. Cream and red walls, bottom cream top red. Cream in the bar area with a little red to tie the areas together. hopefully it turns out decent.
post #15 of 25
All paints are Sherwin Williams
Front wall and ceiling: flat black
remaining walls: bottom 1/2 - raisin, rot 1/2 - rasberry
Carpet wine red (dark)
Wood trim is rich mahogany and front a/v cabinet is frame construction with black cloth covering.
The color combination worked very well.
Colors are nice and dark for HT performance, while also having WAF.
post #16 of 25
Does anyone have their Risers and Stage a different color than the main carpet in the room? For me, its going to be to hard to try and match up the existing carpet. It was in the house when I bought it and I have no idea how to match it up. I figured I could just start with a new color for my riser and stage and it would be used as an accent color. Jus wondering if anyone else has done this.
post #17 of 25
The best possible color (for PQ anyway).
post #18 of 25
celling - Behr "Stealth Jet" Black 780F-7
Projection Wall - Behr "Dark Granite" Grey 780F-6
Other walls - Behr "Anonymous" Grey 780F-5
Trim - Behr "Frost" White
carpet - "dark grey" Not sure of the brand, it was what our installer recommended.
Basically I took the three darkest shades off of the Behr 780F-* color swatch and a trim color that we used on the rest of the room.
Pictures forthcoming.
post #19 of 25
Originally Posted by Chuck1906 View Post
Does anyone have their Risers and Stage a different color than the main carpet in the room? For me, its going to be to hard to try and match up the existing carpet. It was in the house when I bought it and I have no idea how to match it up. I figured I could just start with a new color for my riser and stage and it would be used as an accent color. Just wondering if anyone else has done this.
The best thing about this hobby is its your room. Do what looks good to you. I have seen what you are proposing and I think it works out well when done right.
post #20 of 25
My carpet is black with brown accents. The front wall will be black, and the 3 other walls will have chocolate brown below the chair rail (brown chair rail and base) and burgundy above. My columns will be coverered in black fabric.
I'm up in the air right now about brown or black on the ceiling. I'm using a yellow LED light in the ceiling cove to accent the ceiling, so it's a matter of what will look the best.
post #21 of 25
here is what it is starting to look like.
post #22 of 25
the screen wall and ceiling is black, wall is closer to beige/yellowish, trims and curtain and doors are dark brown, sofa is black, carpet is brown. basically keep it a earth-tone scheme.
post #23 of 25
barn door red for the walls and an industrial flat black for the ceiling
post #24 of 25
the theater area paint is done
so is the dvd storage rack
and the bar(-the counter top)
post #25 of 25
Hi
I am interested in using the same BEHR Anynymous Gray Color - Swatch 780-5 for my side walls, since I already now have a black front wall and ceiling.
I wish to know if anyone else has used this color and if this gray will be too light for a light controlled room with front pj or if the anonymous gray will be dark enough when the lights are out.
Anyone experience with these two colors on your wall? Behr Dark GraniteVS Behr Anonymous Gray for walls?
