Just installed Epson Home 1080 UB in a 14' x 19' 6" room. The picture is being projected on 14' wall and the throw distance is 14' 5" The seats are at about 18' from the projection wall. The room has light blocking window coverings but has usual neutral off-white color on the wall and ceiling that most builders use.
My question is what is the largest size screen I can have in this situation without loosing brightness, sharpness and overall picture quality?
At present I am considering Carada cinema screen with 1.1 gain and brilliant white screen with 1.4 gain. Which one of the above two would you recommend and why?
Also, please let me know if you want to suggest any other make, model of the screens that are worth considering.
