Hi Old,
Thanks for the compliment.
I bought the unit your referring to from smarthome. Shows in stock right now, I had to wait about a month when I bought it last year.
They call it a "5 way Component Distribution Amplifier" 1 in 5 out. I've used it so far to hook up the projector and the Master bedroom set with the cable box which is in the living room. Previously I had done this with Y connectors, when I first connected it, it seemed to improve the image over using the Y connectors.
Ultimately the cable box will be in that closet and it will feed 4 sources Projector, MB, Rec Rm, & Living Rm. I'm glad it has a fifth out as I may add a small LCD by my concession area at some point down the road. Also another caveat is that it has, composite video, and coaxil for audio. This will aid in a monitor inside the closet as well as splitting subwoofer connection for bass shakers.
I would have loved to have done that too....I guess it will be a good idea for my 2.0 Theater....thats probably in another 5-10 yrs if we ever move out of this house.
