Originally Posted by
chef jer
Each tv is slightly different. Additionally, by setting the tv to dynamic it introduces alot of processing by the tv. Try some other settings, cripsy's have grown on me and are what i am using currently. I know it is a pain but try alot of different settings until you find what works best for you
im not new to this thread lol, i had my TV hooked up for the past few days since i got my tv a few days ago , with component for the cable TV and it was great , now i bought the HDMI cable, its the same brand of cable im using for my PS3(got it from monoprice , its the brand new 1.3a versions) but the thing is, its like the Cable TV channels lost quality or something since i moved from the component to the hdmi, i used the extact same TV setting i used for when i had the cable hooked with Component(Monster component cables). i mean i thought it should look better with the HDMI, i dont know the term but when watcing a channel it doesnt look as it should and sharp(hd channels) , i mean it does but not as much as the component. i have 1 question, i have the Monster PowerCenter 800 series (got it as a gift when i bought the TV a few days ago) , heres a link to it:
http://www.monstercable.com/productdisplay.asp?pin=1033
and it has a CABLE IN and CABLE OUT jacks on the side aswell, its says it filters the noise out of the CABLE IN signal so yea well i have my cable in line that comes from the wall in my apartment hooked up into the CABLE IN jack on the monster powercenter, then i have another coaxial cable going from the CABLE OUT on the monster powercenter into my cable box, and finally i have another coaxial cable going from my cable box's CABLE OUT jack going into the TV, all coaxial cables have gold plated tips so no crappy cables. so my question is, this process where im running my signal line through the monster powercenter , im not loosing anything right? i mean i can just be gaining by the monster powercenter cleaning the signal, it cant be that its lowering the quality with all this process of going from the wall to the powercenter , from the power center to the cable box and form the cable box to the TV .
what you think?
