Originally Posted by
jcalabria
Brightness does seem high... Why are you wanting to see blacker than black? Is it posible you have a mismatch on the HDMI Black Level setting? I'm not familiar with the xbox at all... does it use PC grayscale levels (0-255) rather than TV grayscale (16-235)? Are you trying to reproduce the PC grayscale by raising brightness in "TV mode" rather than changing the setting?
I would also be concerned about the Contrast at 95. Most have found that one or more primary will clip with 100% stimulus when Contrast is >92 (or 93 at most), which would seen as a noticeable color shift in bright whites.
Well, I did my basic calibration through the Xbox 360, connected via HDMI. I downloaded a number of test patterns, and I utilized a blue calibration filter I have as well as the "blue only" mode within the samsung settings menu.
The Xbox 360 will output to whichever reference levels or grayscale you want. It defaults to "Standard" (16-235), but there is an option for "Expanded" (0-255).
I used HDMI with black level "low", and therefore used the "Standard" reference level (16-235) for calibration. I have heard recommendations to label the HDMI2 port "PC", and set the Xbox 360 to "Expanded", but it should be the same thing with "low" and "Standard", correct?
Anyway, I do think the brightness is a bit high, but at lower values I
think I'm losing detail in the blacks. For instance, in NHL 10 if a team has black uniforms, I won't see the folds and detailing in the jerseys at anything lower. I always wonder about what I'm [i]supposed[i] to see versus what I'm not. All I know is that when a black screen is displayed, it doesn't really look black because of the brightness. Not sure how to fix it really.
With contrast, I didn't see any clipping of higher white levels until going to about contrast 98 when using Gamma -2. I have a faint understanding of what Gamma does, where reducing the number reduces the jump in each step of the grayscale (is that right?). I just selected Gamma -2 by eye, things looked a little more deep and the rise out of black was a little more realistic. CNET recommends Gamma +3 for this model, but things seemed way too washed out at that setting.
I do notice that with decreased Gamma, I'm able to increase contrast without clipping in the white range, but I'm not sure if that's having a negative effect on other things. Is default (0) Gamma the best option?
I do think the whites look a tad Red, but after watching the TV for a bit that sensation goes away, so I'm guessing that comes from looking at an overly blue monitor half the day at work.
Anyway, thanks for the feedback. I'll try to look at what you mentioned and see if it improves the picture.
