okie dokie outsider, sounds good, let me know
so right now im basically using a modified version of chelhydra's settings, i basically have the same brightness contrast as him aswell as tint and color but i raised sharpness to 50 and backlight to 6. and in the detailed section i enabled DYNAMIC CONTRAST to HIGH and BLACK ADJUST to low. oh and i have it WARM1 , not WARM2, the setting looks preety good i would say, with these modifications that i made, what do u think about these settings? oh on for cable TV i have BLACK ADJUST on HIGH, it makes the channels look better i think, is it wrong to have BLACK ADJUST on high? i mean does it caush black crush? and im not sure what to set sharpness on, whats the most recommanded setting for sharpness? i mean as i change it and try to look what looks better i cant really decide on sharpness.
@Nthstar
regarding your comment about the CABLE cord, im using cable and i have the cable cord that comes from the wall into my aparment hooked up into CABLE IN jack on a MONSTER PowerCenter device which supposdly cleans the signal, then from there CABLE Out into the CABLE BOX's CABLE IN jack, and from the cable box's CABLE OUT into the TV's Cable in jack.
this is the device:
http://www.monstercable.com/productdisplay.asp?pin=592
as u can see on the side theres the 2 jacks. i tried with and without this , couldnt notice much difference but do u think it could hurt PQ in the channels with this hookup via the monsterpower center since its a proccess in other words(from wall to powercenter, from powercenter to cable box, from cable box to TV rather than stright from wall to cable box and from cable box to TV)
