AVS › AVS Forum › Audio › Speakers › Paradigm signature S1, C1, ADP1
post #1 of 3
I know there are not many owners out there yet, but I'm looking for advise on whether you think the S1, C1, ADP1 would be adequate for a medium sized space (13'x28') if setup with a high end sub such as the Sig Servo-15 v2. It is for home theater and multichannel music.
My other option would be Sig S2's up front with the C3 center, but since I'm ok with crossing over the sub even for 2 channel music listening, I'm not sure the S2/C3 will make any significant difference. I know the S2 and C3 both have greater bass extension but at, lets say an 80 Hz crossover with the sub, do you think they would be a significant increase in SPL or clarity over the S1/C1?
All things being equal I would go with the S2/C3 without hesitation, but budget is a concern so I don't want to spend the extra cash if no significant benefit.
Off topic a little here, but it's funny because about a year ago I was a fraction of an inch from pulling the trigger on the S8/C5/ADP3 combo but a beautiful 11 month old son has put a hold on that particular setup. Now I'm looking at the other end of the signature spectrum Oh well, the S8's will have to wait for another day.
post #2 of 3
you might want to post this in the Paradigm owners thread...
post #3 of 3
yea, you're right. If a mod could remove this thread I'm going to post in the paradigm thread. Thanks
  Back to Forum: Speakers
