post #1 of 1
I used the DVE BD disc to calibrate the regular user settings of my Panasonic PZ750U, however, need some help in how to calibrate the Pro Settings, specifically Gamma Adjust (Normal, Mid, Full 1, Full 2), white balance for light and dark red areas, white balance for light and dark blue areas. Using the Pro model Panny series Gamma settings (S-Curve, 2.0, 2.2, 2.5), I'm guessing there is a direct correlation although not certain as the Panasonic help desk didn't know either. In reading Gamma threads, my understanding is that I should keep it at 2.5/Full 2, although it would be nice to set it according to a test pattern. The Black Extension setting is supposed to adjust grayscale, however, increasing it above it's default of 0 introduces black crush so that setting is useless as the lowest setting is 0. The 700/750 calibration thread wasn't able to provide any guidance. This is my first use of a calibration BD/DVD so any help, especially from a more advanced owner of a PZ750U or Pro Model series Panny (although I'm guessing these same settings are similiar in other higher end brands of plasma HDTVs) would be welcomed. Thanks.
