Here is a floor plan of the front part of my upstairs that I plan to turn into a theater area. in the lower left corner is where i plan to place my "home theater" I just need some insight on where i should mount future 58" plasma. I get a lot of afternoon sunlight from the large window but I plan to replace the current curtains with blackout ones. I also will eventually go with a 5.1 set-up.
WALL A = 12ft
WALL B = 11ft
So my question is if you had this layout would you place the plasma on Wall A or Wall B? Or in the corner?
Here are actual pictures of the area
Large Window
Thanks for the help. AVS has been a great info site for me.
WALL A = 12ft
WALL B = 11ft
Large Window
