AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Is it possible to get 480p from PS2 to a vga input?
post #1 of 7
I know that it's possible with some type of upscaling device, but I'm looking for something affordable. Basically, let's say that you have a PS2 system, and you want to hook that PS2 system up to a LCD flat panel computer monitor with a VGA input. I know there are a number of cheapo upscalers that you can use with a PS2 to get it to work on a VGA monitor, but I'm pretty sure the vast majority of them basically take a composite signal, and cheaply upconvert that, and then output it as VGA.
I'm interested in some type of VGA box for the PS2, that will let you get true 480p from the games that actually support 480p, and the ones that don't support 480p, it would take the 480i and upconvert to 480p, and then output that via VGA.
I'm not sure if such a device exists, that's actually affordable. But if anybody knows of one, please... do tell...
post #2 of 7
Hi There,
Here is the perfect solution
http://cgi.*********/DVDO-ISCAN-PRO-...QQcmdZViewItem
post #3 of 7
sorry about the bad link, here try this one
http://*******.com/3lzr5m
post #4 of 7
DVDO ISCAN PRO Line Doubler is a good solution, you can find dirt cheap on ebay.
post #5 of 7
DVDO's for cheap? Seriously? Last time I looked at anything like that, it was several hundred dollars at least. I don't need to see the PS2 in 480p on a LCD VGA monitor that bad. I could get a X2VGA 2 for $60, plus tax and shipping, but I've heard mixed reviews on the video quality, and by the time I've paid tax and shipping and all of that, it's costing the same as my PS2. I'm trying to find something that works good for like $30. Of course, maybe getting a device that will do want I want it to do for only $30 is an imposibility.
post #6 of 7
dude check on ebay seriously, I see many credible auctions with a iscan for dirt cheap.
post #7 of 7
Find an old X2VGA+ or something that carries component-in and VGA-out. They work off the 480p signal. Alternatively, you could build a component-to-VGA transcoder yourself with DIY plans available on the internet.
  Back to Forum: PlayStation Area
