AVS › AVS Forum › Audio › Speakers › Where is my surround sound?
post #1 of 46
I spent good money on this system and I just do not hear the Wonder of surround sound.
I am running pioneer vsx92 receiver to mythos eights left,right,center and Speakercraft Aim eights for rears, and Supercube II. 5.1 set up.
I tested the system out with Blue ray dvd Casino Royal which is I believe Dolby Digital 5.1. I am using PS3 and have it set to PCM but I also can switch to bitstream not sure if I hear a difference or not.
The sound from the front speakers (Mythos) is phenomenal but I noticed I really do not hear great surround sound coming out of the Speakercrafts rears. Very low. Sounds like all the sound is from the front. I realize most of the sound comes from the front, but I think I should be hearing more clearly and louder the background sounds from the rears.
I went into the receiver to adjust the level from 1.5dB to 2.5dB and it seemed to sound a little better I then went to 3.0dB and not sure if it sound any better maybe even worse then 2.5dB. Is there a optimum level that should work Best?
The mythos fronts are set at 0.5dB Should I be adjusting the rears louder or the fronts lower?
Please help.
post #2 of 46
Have you run the MACC auto-setup? It will set the levels of all your speakers so that they are equal at the listening position. This will solve your problem.
Craig
post #3 of 46
The right level for your speakers is when they are all at the same loudness.
You really need a sound level meter to test this. I'm sure your reciever has a test tone. This will send a sound to each speaker, one after another. Make sure each speaker is the same loudness.
As far as the right number setting, it can be all over the place. My center channel is currently -4 and my surrounds are +4 and +5. But this will be different on every system and room so don't just use these numbers.
post #4 of 46
Craig
I did not no. But the installer I know he tested out the sounds but not sure if it was auto set up or manual. But I can tell you the mic from receiver was still in the bag sealed. So my guess is it was done manually.
The MACC auto set up I will use the mic that came with the system?
post #5 of 46
Yes, the MCACC uses the included mic. Set it as close to ear level at your listening position as possible. Using a tripod is sometimes helpful.
Why would the "installer" not use the MCACC? It does more than a simple level adjustment. It also sets speaker distances, sizes and crossovers. It checks the reverberant sound field and adjusts the output to minimize the impact:
http://www.pioneer.co.uk/files/eur/MCACC/index.html
I would write down all the settings the "installer" came up with, then run MCACC. If you don't like the settings it comes up with, you can always go back to the installers settings.
Craig
post #6 of 46
Yes, the MACC uses the included mic. Set it as close to ear level at your listening position as possible. Using a tripod is sometimes helpful.
Craig
Thanks for the info so far it all helping me. My wife was disappointed with the surround sound. So hopefully this will make it better. It should have a WOW factor.
I was there he definetley set the distance, etc. but I know it was all manual. I did not see any mic in his hand and he seemed to be listening. But there was noise in the room from them working.
So, the auto MCACC sets everything for me even the distance, etc. Seems amazing but makes sense, why do it manually then?
PS: does movie like 300 which is TrueHD going to sound better then Casino Royal with is just Dolby Digital?
ALSO GREAT LINK. I cant wait to do this tonight.
post #7 of 46
Some folks don't like the MCACC settings. That's why I suggested you retain the installer settings, so you can go back to them if you don't like what MCACC comes up with. If people don't like the MCACC settings, the thing they usually don't care for is the EQ settings. Therefore, the other option is to keep all the settings for levels, distances crossovers, etc., but to turn off the EQ.
Also, be sure to check the speaker size settings. Sometimes it will set speakers to "Large" that really should be set to "Small". Report back with what it comes up with and we can help you optimize the settings.
Craig
post #8 of 46
Craig
I will do just that. Ill write down all the setting mcacc comes up with. I really appreciate your help. I feel like there is hope. Il be back in the morning with the results.
post #9 of 46
One other thing... the subwoofer distance may be different than the "actual" distance. MCACC actually measures the "acoustic" distance of the subwoofer. This distance is sometimes longer than the actual distance because of the Bass Management processing and any filters used in the subwoofer amplifier. The processing in these systems takes some time (milliseconds) and that time needs to be factored into the distance setting. If MCACC calculates a distance longer than the actual distance, keep it.
Craig
post #10 of 46
Craig
Got it. Thank you again. You threw me a life saver. Il have results in the morning.
post #11 of 46
I have a VSX81 and the sound is great. I have my PS3 set to bitstream and all speakers work fine.
post #12 of 46
bitstream interesting. Ill know more tonight.
I thought Ps3 needs to be on PCM for truehd and dts and bitstream on all others. Or can I now live it on bitstream for everything since the firmware update.
post #13 of 46
I ran the auto test and this was the results.
Speaker Set up
F, C, Surr=Small, SW = Yes.
Showed 5.1
Channel Level
L = -10db
C= -10db
R= -9db
SR= -10db
SL= -10db
SW= - 9.5db
(it told me to lower the sub volume so I turned it slighly lower then half way point) (notice the R = -9db, should I even it out to -10db)
SP Distance
L = 10' 05"
C= 10' 06"
R = 10' 05"
(this was pretty much on target from the actual distance)
AC Cal EQ
63 -------
125 -5.5
250 -4.5
500 -2.0
1 -3.5
2 +3.5
4 +0.5
8 -0.5
16 +2.0
Trim +1.5
So, does this make sense. I played 007 Casino Royal on PS3 and it sounded good. The originally installer had the front speaker level set at -0.5 and rears at -1.5 much different then the Auto. My question is to hear more of the back speakers (Surround Action) should I change the rear speaker level to higher then the fronts.
Also, am I going to here more surround sound from a movie like 300 which Truehd compared to Casino royal which is Dolby Digital. Also would I be wise to be using my panny bd 30 instead of ps3 for sound quality.
Lastly, I notice if I play PS3 at PCM vs. bitstream with Dobly Digital it sounds much lower with PS3. Does it also sound worse or better.
post #14 of 46
bump...
post #15 of 46
sigh...PS3 should have latest firmware and be set to PCM. This is the ONLY way to hear TrueHD and DTS-HD soundtracks. If you have a BD30, why are you even using the PS3 for blu-ray???
post #16 of 46
Cause my bd30 is in my dininig room on my 40" LCD. Id like to have ps3 in mY HT where it stands now. But I am thinking of switching it for simplicity both in remote control issues, and sound.
But for now I have to fine tune my receiver and speakers. HELP
post #17 of 46
Fit2Run,
I have a totally different question for you. What acoustical treatments have you done for this room? It is the most important part of the sound you are going to get in that or any room.
I agree with all the other info you have recieved but if you try all of it and still don't like the sound look to your treatments.
post #18 of 46
Not all 5.1 disks will deliver sound images to the rear surround speakers. Look on the back of the BR jewel box the disk came in and read what codecs or surround processes the disk was recorded in. The front soundstage does 80% of the work. Your not going to get continuous sound thru the rears. That would be more like 5.1 stereo, a DSP mode.
post #19 of 46
Are we supposed to magically help you over the internet somehow? The MCACC readings look reasonable, I don't know what else you expect us to comment on?
Surrounds aren't supposed to be constantly blaring in your ear "hey look, you've got surround".
post #20 of 46
Originally Posted by McCall View Post
Fit2Run,
Right now it is a empty room with hardwood floors. I am getting furniture delivered in a few weeks. Sectional, area rug, recliner (all leather). Two windows that get no light they will be covered with shades.
So acoustically the room may not be the best certainly not right now. I will have to rerun the TEST afterwards.
post #21 of 46
No your not. But I am getting good advice from many people which gives me an idea of what to do if anything. I am getting a comfort level at the very least.
PS: I agree HEY LOOK I HAVE SURROUND. I think casino royale is not the best DVD to showcase for surround sound.
I have yet to test the new MCACC readings so Ill test it with movie 300 on the bd30. If it sounds good then im done and Ill just rerun test when I get my furniture.
post #22 of 46
Honestly, I'd stick to whatever your Pioneer auto-setup feature dictates. It seems to me that you're not 100% sure of what kind of sound you SHOULD be getting, but have a perception of what you thought it was.
These auto-setups are not half bad most times, so you can be sure you're not missing out
I mean, let's not forget your speakers are not all identical, which would definitely affect the over coherence of the surround sound experience
post #23 of 46
Rynberg, your comment is uncalled for. He's trying to figure this out so give advice or don't but let's not berate the guy.
To the OP, I'd suggest getting a sound level meter from Radio Shack and set your speakers manually. I'm not a fan of the auto calibration. Once you have the meter do a search on here and there is a lot of information that will help. You want all the speakers to have the same level on a test tone. Your sub should be the same level but the meters from Radio Shack are slightly off and you have to adjust them for that. I'd leave the distances where they are it, sounds like your setup did well with it. Also there is a thread on here about great movies for surround sound try some of those movies. I hated Casino Royale so haven't watched it on DVD to tell you if it's a good one or not. Not all movies have great surround effects. Others will chime in on that issue I'm sure.
But as rynberg stated your surrounds won't be blaring sound out at all times, only when needed. Surround is very subtle and a well set up system is great when the movie has a good surround track. Best of luck
post #24 of 46
You beat me to it. I think you need a different movie as I stated above. I know Cars was pretty good and The Incredibles is excellent. Also try Transformers.
post #25 of 46
Thanks for backing me. and giving good advice. I am going to absorb it all and make some decisions. One is to get transformers for sure.
PS: does it matter much that my rears are speakercraft in ceiling and I have mythos 8's and fronts. I could have gone all the same brand. But I was told as long as the front l,R,C are the same I am fine. I do not think the rears have to be a perfect timbre match.
post #26 of 46
In the past, I was not thrilled with any of the EQ modes on auto-cal setups either. However, I found that the ones I tried, YPAO & MCACC, did a pretty good job at setting levels and distances. They would do just as good a job as an RS SPL meter, and no correction tables for meter adjustment were required. Also, the distance settings are more accurate than a simple tape-measurement, for the reasons I described in post #9 above.
They would often get the speaker sizes incorrect, setting many speakers as "large" that should correctly be set as "small", but that was easy to correct. Just re-set them to "small" and pick an appropriate crossover. However, I never liked what any of them did with Auto-EQ. They would screw up the imaging or the dialogue and I always preferred the EQ's set to "Off".
I now have an Onkyo 885 pre/pro with Audyssey MultEQ XT. It is a much better "auto-EQ" than any of the others I have tried. It seems to correct the FR without impacting the imaging. It also nailed the level and distance settings. It incorrectly found my Atlantic Technology 8200e's as "Full Range", but I simply reset them to an 80 Hz crossover.
The MCACC has a room correction EQ, which I suggest the OP try both On and Off. If he's like me, he'll prefer it Off, but it's possible, in his room, he may like it. However, the rest of the settings seem appropriate.
And McCall is absolutely correct that room treatments will be the best improvement the OP can make.
Craig
post #27 of 46
I think the Ultimate surround test on Blu-ray would be the movie WAR if you have or have considered getting it. Phenominal use of surrounds in this...2 others would be Black Hawk Down and Tears of the Sun. These movies will let you know if your surround is working properly and from there just knowing that all movies are not created equal in the surround department. Some movies just have bland and less than adequate soundtracks....even on BD. Check out the Sticky thread in the BD Software section for a list of some of the best soundtracks in addition to the ones I have mentioned.
http://www.avsforum.com/avs-vb/showthread.php?t=918734
post #28 of 46
Craig, I defer to your knowledge as you have way more experience than I. I know mine is terrible. I have the Yamaha htr-6090 and I don't know if it's the receiver or the horrible accoustics in my room, but the auto-cal is terrible. I've used 2 different mics and same thing.
Fit2run, I hope you've gotten enough info to get you started. I agree that the rears are not as important to be timbre matched. For what it's worth I've never understood people that chime in a discussion just to be confrontational. Most on here are helpful and informative. Although they will bust your b@lls on occasion.
post #29 of 46
Channel Level
L = -10db
C= -10db
R= -9db
SR= -10db
SL= -10db
SW= - 9.5db
Audyssey does similar thing where it adjusts everything down.
You should adjust all these settings manually using you lowest adjustment (R) as the base. Thus you should end up with the following:
L= -1 dB (10-9)
C= -1 dB (10-9)
R= 0 dB (9-9)
SR= -1 dB (10-9)
SL= -1 dB (10-9)
SW= -.5 dB (9.5-9)
post #30 of 46
L= -1 dB (10-9)
C= -1 dB (10-9)
R= 0 dB (9-9)
SR= -1 dB (10-9)
SL= -1 dB (10-9)
SW= -.5 dB (9.5-9)
The only thing this will do is change the Master Volume Setting for Reference Level. However, it won't hurt anything either.
Craig
Edit: There is one other thing it *could* do. If the subwoofer is not receiving a strong enough signal to activate it's Auto-On function, raising all the levels like what was suggested can help with that. Of course, the same thing could be accomplished by lowering the level of the subwoofer amp before calibration. This will force the receiver to send it a stronger signal.
  Back to Forum: Speakers
