AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › PJ and PC's who's doing it? Tweaks, etc
post #1 of 4
I have seen a few people who are using there projectors with a PC or a HTPC.
Just want to see if we can pool knowledge, hints, tweaks.
Example of one recently found that helped me was
Originally Posted by Peter_ View Post
Is important to say that I don't have Blu-Ray Player and I use the filter Sharpen of ffdshow to increase sharpness of all movies.
I use the Media Player Classic + K-Lite Mega Codec Pack + QuickTime Alternative.
This increases the sharpness of all movies, and with that I can take better sharpness of the projector.
Why buy a projector with good sharpness, if the films are smoothed.
So what other tips do people have that we all may share in this knowledge?
For those using Media Center if you run the wizard you can set the resoultion to say 720P vs your desktop (which tend to be higher).
If you use Codecs to play files they dont "lock" down your system like Media center does. This allows you to surf and watch a movie/play games etc as needed.
post #2 of 4
The home theater PC forum has a ton of information on this topic.
post #3 of 4
Yes but its scattered and mostly dealing with the building process/hardware and or connections to TV's.
Just trying to get people who are using a projector with the PC in one spot.
Still if an admin thinks thats a better spot by all means move this topic
post #4 of 4
Subscribing to this as I'll be purchasing a projector and building an HTPC in the next couple months, and the software side of it has my head spinning. It's even more complicated than picking a screen
