AVS › AVS Forum › Audio › Receivers, Amps, and Processors › My Yamaha RX-V663 and...
post #1 of 11
So I got the Yamaha RXV663 and was thinking about pairing it up with these to start off. They are all Klipsch:
1 - RC-62 Center Channel
2 - RF-52 Towers
1 - Ref 10 Sub
2 - RS-42 Surrounds
Please let me know if you guys think that will be a good starting setup in my room which is 20'X17'
post #2 of 11
Klipsch + Yamaha = too bright for me. I'm sure you could push those speakers really loud in that room though, they are super efficient.
post #3 of 11
Klipsch + yamaha = too bright? sorry if i sound retarded, but i dont get it.
post #4 of 11
Many people do not like the sound of the horns in a Klipsch (browse any of the many threads pertaining to Klipsch and you will see that people either love em or hate em). The previous poster thinks it's even worse with a Yamaha.
Have you gone to listen to the Klipsch yourself yet? Do you like them (are you in the 50% that's loves em or the 50% that doesn't)? What receiver was being used in the demo you heard?
post #5 of 11
I can't say Klipsch are bright or not bright, but I could believe their horn designs may give it a certain character.
I never found Klipsch to be too appealing when doing listening tests in stores (which are not real reliable.)
On the plus side, Best Buy replaced a blown Klipsch* no questions asked from their own stock. Fantastic policy if this is still the way it's done. My thanks to Klipsch for offering such a great warranty policy.
Most stores have a reasonable return policy if they don't work out for you. You can always tweak the treble a bit which could tame some brightness, but that's of limited value.
* I needed a cheap pair of monitors, and they fit the bill. I now use them for my rear surrounds
post #6 of 11
+1...
On a side recommendation, for the money, the Paradigm Monitor line is hard to beat, IMO.
post #7 of 11
well, to be honest, havent heard them at all yet, reason being i can get 50% off on all of that stuff. total on the equipment above was around $2500, but i could get it around $1250...
post #8 of 11
YOU need to go and listen to them.
If YOU like them, 50% off is a great deal.
If YOU don't like them, it would be a waste of $1250.
With a reasonable amount of patience you will always find a good deal on something you like - but until you know what you like you don't know what deals to look for.
post #9 of 11
Under those circumstances, that would absolutely warrant a demo...
post #10 of 11
thanks for the input guys, just wondering if u guys have any other recommendations of other speakers that would pair well with my yamaha rxv663 in the price range i showed above.thanks
post #11 of 11
Besides my previous Paradigm recommendation, PSB and Energy have excellent speakers in your price range, IMO.
