I decided to make my screen 100" wide.
Therefore I multiplied 100 x 9 / 16 and got 56.25 for the height.
I then made the borders wider on my 120" retractable screen so that the image area is 100" x 56.25" exactly.
The problem is I can't seem to get images that I think are 16:9 to fit the screen area. I should mention that I have to do some keystone correction to square up the image since I do not have lens shift. I usually use the main menu of the Terminator II DVD to fit the image to the screen.
Questions:
Did I do the math right?
Does the keystone correction screw up the aspect ratio of the image?
On most DVDs, are the main menus 16:9 or are they that funny size that has narrow bars top and bottom.
Is it possible that there is something odd about the HD72?
It is actually 1280x768 resolution.
I would think the best course of action would be to make the screen 16:9 and live with the miss fit since I am likely to replace this projector with a 1080p unit when the bulb burns out. Sound reasonable?
Thanks in advance for any suggestions as to what may be wrong.
Questions:
