I was wondering if the monster screen screen cleaner is a safe/good product for cleaning the 5080 kuro. I used it a couple times on it, the first time I sprayed on the screen(I KNOW NOW BAD IDEA) and it left alot of streaks on it.
Upon calling BB they told me to spray a couple squirts on cloth and use it that way and it did take the streaks away. but now it seems that there is like a purple haze on parts of it when the tv is off and im looking at it from a side angle. I only see it with a little bit of sunlight on it. just wondering if this was normal or the screen cleaner doin it.
I did read the manual and now only clean it with the cleaning cloth supplied, but just lookin for advice from other people that may have used monster screen cleaner on the 5080. I dont want to take off the coating on it
