I am setting up my theater room using the following:
Pioneer Kuro 60 inch plasma 150fd
B&W 804s for fronts
HTM3S center
Ds8 dipolar rears
Sunfire Signature EQ sub
NAD preamp and amp
DOES THIS HAVE POTENTIAL FOR A GREAT HT??
I want to get the best sound possible. I will sit 10' from the monitor so that i am equal with the distance from my fronts from one another. I am trying to create as close to an equalateral triangle as possible.
!) QUESTION- That will put my fronts around 1' from the side walls. Is that enough? They will be around 2 1//2' from front wall.
2) Because I am only sitting 10' from monitor I will be 13' ft from my back wall. That seems pretty far away from the rear wall.
a) Is that an acoustic issue? Does it help or hurt being so far away?
b) What kind of acoustic treatment should I use on the back wall- absorbant shields or dissonance or none?
3) I want to do a good job with acoustic shielding.
a) I am thinking a shield on the front wall behind each front speaker (excluding center).
b) First reflection points on side wall using mirror trick.
1) Should i do ceiling first reflection point (flat drywall)?
2) I have carpet on the floor.
c) What thickness should I use on the absorbant shields 1" or 2"?
d) How important are bass traps and where should I put them in the top 4 corners or just the middle of the four corners?
THANKS FOR THE ADVICE!!!!!!!!!!!!!!!!!!
B&W 804s for fronts
HTM3S center
Ds8 dipolar rears
NAD preamp and amp
