With this new analog to digital conversion coming up soon, I was wondering if there would be a way to simplify this process. Here's what I had in mind:
My house is wired for cable, but we still use standard over-the-air antenna. Since the house is already wired, we set up a rooftop antenna inside our attic and attached to the cable wiring. So, now all the TVs in the house are plugged into the cable jack in the walls, and they're all drawing off the antenna in the attic for their reception (all analog TVs). Now, I was wondering if it would be possible to simply put ONE digital-to-analog converter box in the attic (perhaps after the antenna and then route that into the house's cable wiring) and then have all the TVs simply use that signal. This would save the hassle of buying / setting up multiple boxes for the multiple TVs. Would this be possible?
I am not well versed at A/V terminology, so try to keep it in simple terms, if possible please.
