AVS › AVS Forum › Video Components › Home Theater Computers › Intel G35 chipset doesnt have 1280x960 and 1280x720
post #1 of 22
I have purchased a Asus P5E-WV HDMI motherboard with the Intel G35 chipset and have connected it to a LG 42PX5D 42" Plasma TV.
The ideal resolutions to get the best output from my tv are 1366x768 or 1280x768. However, I do not have the option to select these resolutions and the closest is 1280x960 and 1280x720 which are not compatbiel with my tv. 1280x720 is not compatible with plasma so i'm currently using 1280x960.
I have downloaded the latest drivers and installed winvista_1582bb.exe but still don't have these resolutions avaialable. I have tried unticking "hide modes that this monitor does not support" and have tried "list all modes" to no avail.
COuld anyone please help me and tell me how to add these resolutions?
post #2 of 22
Hi andyking
You need a program called DTDcalc for custom Intel resolutions (I have ASUS P5E V HDMI and can get almost any resolution and frame rate using this tool). For more info check out this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=947830
The guys and gals there are really good and will help you with what you need. Hope this helps you out.
Cheers,
Jiff.
post #3 of 22
Hi JiffOrange and thanks for the reply.
It's good news that this can be done and after reading through the info i've installed dtd calc. However, i'm still not sure how to get the dtd lines for the resolutions i require.
I've posted a message on page 18 of the forum so hopefully they can help!
post #4 of 22
Ask either Wo0sy or archibal...they are the gurus. It is possible to use standard settings and then alt4er them to suite.
Hope this helps,
Cheers,
Jiff.
post #5 of 22
Not sure where you got the 'ideal resolutions' for your TV, or how you determined that 1280x720 is not compatible with your TV, but here are my thoughts on this. Over HDMI you should not be aiming for 'native' panel resolution, as this is not what most TV's expect. a 720p signal will not necessarily be 'scaled', but there is always an internal 'panel-mapping' process which fits the input resolution to the actual pixels on the panel. For a 1366x768 panel, the 'native' resolution is actually 720p over HDMI, this is then panel-mapped to 1366x768. Other resolutions, e.g. 576i are scaled up to 720p internally, and then also panel-mapped to 1366x768. For the panel in your TV, 720p is almost certainly the 'right' resolution. However, it probably overscans by default, which is fine for video, but you will lose some of your desktop. To overcome this, first attempt to reduce/eliminate overscan on the TV either through normal or service menu's. If this has been unsuccessful, then you need to start looking at custom resolutions to reduce the overscan. This is where DTDCalc comes in useful, as it lets you create custom resolutions. Best bet is to start at 720p and adjust it to fit, then save this and apply it to the registry
post #6 of 22
720p signal will be scaled to fit the pannel, their is not sufficient data to cover the panel so some type of internal scaling in the TV will have to be done ('panel-mapping' is scaling!!!). Most TV's will except differant resolutions to 480/575720/1080p over HDMI and it is more of a case of the quality of the computers scaling vs that of the TV's internal scaler. Use whichever one is best.
Jiff.
post #7 of 22
Jiff.
This is not the case. Feed a 1366x768 signal over HDMI to most panels, they will firstly scale to 720p, then panel-map back to 1366x768. The scaling and panel-mapping processes internally are separate, scaling occuring first at a more 'software' level, then panel-mapping at a hardware level directly to the PDP. I know 'panel-mapping' is scaling, but I am using this as a separate term to try and highlight the different internal processes that occur. I'm thinking I might have to start delving for some backup to prove this fairly soon, but can't remember where I read it! ;-)
post #8 of 22
Fair enough.....supose that a two process system is possible. The more you know :-)
Jiff.
post #9 of 22
DVI however might be a different story...I think its the limitations of the HDMI interface that requires the initial conversion to a 'recognised' resolution e.g. 720p/1080p
post #10 of 22
While I won't argue with eeit232's logic, andy's Diagnostic Report shows "Generic PnP Monitor" via Analog so I'm guessing he's using a VGA connection. If not, there's something very wrong with the report.
andy, can you confirm your connection type? I'm currently looking through your TV's manual but in the meantime you might want to try the following DTD
66 21 50 B0 51 00 1B 30 50 70 36 00 00 00 00 00 00 1E
A few people have had success with this so far.
Wo0zy
post #11 of 22
According to the manual I found on LG's site, this TV's native rez is 1024x768. Manuals can be lies, of course.
post #12 of 22
I used to have the LG42PX4D until yesterday (new Panasonic on the way!).
I ran it routinely at 1280x720 and it also worked just fine at 1024x768. I think your model is slightly newer than mine but otherwise the same. I wonder why you can't select 1280x720.
I think the 1024x768 native res is over VGA- hdmi supported either (well, for that matter, so did vga).
post #13 of 22
Hi guys and thanks all for responding - it's very much appreciated.
Wo0zy, that dtd you gave me works perfectly! thanks a million for that. Now i can watch hd vids without black lines at the top and bottom in 1280x960. Where did you get that dtd from and do you happen to have the dtd's for 1280x768 and 1366x768 as well as 1360x768.
The diagnosic report i sent was actually the vga connection. I've attached the hdmi one. I've been trying both vga and hdmi to get the best output.
rainmaker002, not sure how your LG42PX4D worked with 1280x720. When i set it to that res it overshoots the screen.
thanks again for all your help.
DiagnosticReport hdmi.txt 2.83984375k . file
post #14 of 22
Glad it worked andy,
I thought your diagnostic report was probably from the VGA port
The problem you're having with 1280x720 (720p) is typical overscan. You can use DTDCalc to adjust this and see if the resulting image looks better than your current one or not.
I got the 1360 DTD from someone who was experimenting with DTDCalc a while back and it seems to have done the trick a few times now (at least when the display support 1360x768 over HDMI ).
Based on that timing, 1366 will be
66 21 56 AA 51 00 1B 30 4D 70 36 00 00 00 00 00 00 1E
Will have to see if I can dig up a 1280x768 for you. I have a 32" LG which supports it so I'll try and get the timings from that. If not, as Archibael suggested, see if you can find a modeline through the magic of Google and we can convert that.
Good luck.
Wo0zy
post #15 of 22
Isn't there a utility within the intel drivers that lets you make minor adjustments to the size of the screen? I think I used that to get it to fit with my LG at 1280x720. I wish I could help but I have no tv anymore and my memory ain't so great.
post #16 of 22
TVWizard does this on some chipsets, but I think it uses panel fitting aka scaling. 1:1 pixel mapping with DTD Calc will probably have superior results.
post #17 of 22
Ok thanks for that Woozy. I'll give it a go with the 1280x720 using dtdcalc. However the 1360x768 looks pretty good .
rainmaker002, are you talking about the aspect ratio adjusters provided with teh intel graphics properties? I used that and pretty much had to move them to the lowest settings for the screen to fit but it didnt look good and caused problems with the screen size in media center. Anyway, woozy has hit the nail on the head .
post #18 of 22
Hi woozy
did you have any luck in finding that dtd for 1280x768? I've had no look with google i'm afraid.
post #19 of 22
Furthermore to my previous post, that's not strictly true. i did find a modeline for 1280x768 at 60Hz but dont know how to convert it to a dtd.
"1280x768" 69,000 1280 1280 1300 1424 768 769 775 812 -hsync -vsync
post #20 of 22
Hi andy,
Converting modeline to DTD is actually very easy if you use DTDCalc. All the values down the LHS correspond exactly to the Modeline values so for instance
Pixel Clock=69
H Active Pixels=1280
H Start of Sync Pulse=1280
and so on.
The odd thing about the modeline you've posted is that the Horizontal Sync Pulse appears to begin directly after the active pixels finish which is unusual (no Front Porch as they say in Powerstrip language).
By all means give it a try but I'm not sure it will work.
Wo0zy
PS. Have you tried tuning the existing 1360x768 timing using either the ruler tool or the fine tuner? Might be worth trying.
post #21 of 22
Hi and thanks for your reply. I did use dtdcalc to adjust the 1360x768 res by setting the h active pixels to 1280 but it didn't look right. I must be missing something as all other values stayed the same.
post #22 of 22
I started this thread some months back and with woozy's help got the 1366x768 and 1360x768 res's to work fine.
However, i've been unable to get 1280x720p nor 1920x1080i working as it still overscans. i opened a new thread at http://www.avsforum.com/avs-vb/showt...6#post14865206 but the advice given there hasn't got me anywhere.
Woozy, is this something you could help with?
rainmaker002, you mentioned that you had it working at 720p - was this without overscanning?
