So, I have determined that the odds of a pass-through box being in stores near me are practically nill, at least before my coupon expires, so thought about a switch install so I can still get analog.
Found the following on Consumer Reports, but it sounds way more involved than I thought it should be for a TV with only antenna input...
So, do I really need two switches, etc. Here's what CR says:
>>>>For TVs that only have an antenna input connector (no separate video inputs), you'll need both an RF antenna splitter and an antenna A/B switch. The splitter should be connected between the antenna and converter box, with one cable connected to the DTV converter box's RF antenna input, and the other going to one of the inputs on the 2-way A/B switch (effectively bypassing the converter). Then run a cable from the converter box's RF output to the second input on the A/B switch. The A/B box's single output is then connected directly to the TV's RF (cable) antenna input. When the A/B switch is on the "digital" (A) side so it's receiving the converter box's signal, tune your TV to channel 3 or 4 to watch digital programs. When you click the switch to the "analog" (B) setting, you'll be able to view any available analog programs by changing channels on the TV. The downside is that you'll have to manually switch between the two inputs on the A/B switch every time you want to switch from an analog channel to a digital one.<<<<<<<<<<br />
Anyone??
Anyone??
