AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Sammy 5084 question....
post #1 of 5
On my picture size options, it has 16:9 and also Just Scan. Which one should I use and why? What is Just Scan?
post #2 of 5
check out the 5084 thread and do a search for just scan. covered ad nauseum in that thread.
post #3 of 5
you know if might have taken you less typing to just tell me what it is.
post #4 of 5
Just Scan = 1:1 pixel mapping. You'll see every pixel of HD shows, just as it was intended. 16:9 stretches the image slightly, expanding it past the edges of the screen. 1 freebie from me. Now do yourself a favor and read the 5084 thread. Or at least RTFM (would have answered your question also).
post #5 of 5
you would have had your answer if you had just searched just scan in the 5084 thread.
