Not sure if this is the right place to post this (I bet you haven't heard that one before), but I have an HDTV with only one set of composite-cable inputs (the red, blue, green). I'm using this currently for my HD box, but want to hook up an Xbox 360 similarly. The TV also does not have an HDMI port (it's old).
My question is--do you folks recommend any particular composite switcher/selector that hopefully doesn't degrade HD quality? I'm wondering if that might just be a given.
Alternatively, should I look into HD receivers? I have no idea where to start and some of the price tags are a little scary ($400 plus, etc.).
Thanks in advance, and feel free to point me in the right direction if this query has been answered before. I did not notice it in the stickies or search.
