after i am "almost sure" that i can find a way to feed my 3d pictures
2048x1080 with one computer via one dvi out
to the barco dp 2000 and this pr. can display it at full resulution
in 144 hz flicker free (2x72 hz per eye)
i order this unit.
i had in the past 2 christie hd6k 3 chip dlp pr. 1920x1080 with 1000 watt xenon
and i like this pr. a lot.
no pr. that i have during the last good 1 year at my home can match the
picture quality this christie pr. had.
i use 2 because i do 3d with a 3m wide silver screen with passive polarizer.
it works fine but it need always much time and adjustments to switch between
2d for films at the big 7m 2.35 screen and 3d at the small 3m silver screen.
my goal was to do 2d films AND 3d pictures at the same big 7m screen (harkness hall matt preview gain 1.0)
with only one pr.in shutter for 3d.
i saw some 2x 60 hz 3d but i can see some flicker so the only way was to
buy a cinema unit that can runn in 144 hz flicker free.
there was only two projektors at the moment that can do that
at the full resolution 2048x1080 in 144 hz.
the barco dp 1500 and the barco dp 2000.
both units are identical more or less.
the 1500 can take lamps till to 3000 watt the dp 2000 till 4000 watt.
both using the new 0,98" cinema chips 2048x1080 with dc4.
there is a lot of work for the pre instalation as you can see in the first pictures.
new much stronger power supply is need havy intake air strong filtered to protect the unit from dust
and exhaust air all that the christie pr. all not need.
how it perform against the christie hd 6k
is cinema prozessing really better?
did i can do 3d as i hope?
what problem the pr. have?
that all later.
i order this unit.
that all later.
in front of the 7m screen?
