Originally Posted by
darthsphinx
-poor SD
-not enough setting tweaking
-Poor sound
-motion although the best I've seen not where it should be
-Price
Well I don't understand the comments above ....
You say motion is the best you've seen, so surely that's a "Pro".
As for the sound, this model has a built in woofer, you should try the many other LCDs that don't if you really want poor sound.
Samsung are also one of the best on the market for settings tweaking allowing separate stored settings for every input and have added even more adjustment options to this model including Flesh tone.
These setting options should enable you to achieve substantial improvements on SD performance (although it will never match your old SDTV)
As for complaining about the price, well no-one forced you to buy it.
