Originally Posted by
Ready2Mosh
Yes I did, it came loaded with 1004 and my TV seemed to have the uneven audio issue when you mess with the EQ. When I updated it did the 999999firmware number thing then asked if I wanted to update to 1007. I find 1007 to be very smooth and works very well. I also am using ZeroGs calibration settings and find them to be excellent for deep blacks without crush and saturated colors without looking un-natural.
Mosh~~
Mosh, can you explain what your uneven audio symptoms were?
I was listening to test tones on the AviaII disc, and noticed that my set seems to lack bass in the right channel. I even swapped left and right inputs to be sure, and still the right channel sounds like a tin can.
I think I had it on a pre-set, but cannot be sure at this point.
I didn't really want to hit 1007, since I prefer the lower AMP (actually, I have been leaving it off most of the time.) But if it will fix the audio, I'm gonna have to do it.
