Ok folks, I've been getting a lot of responses and questions to the way I achieve the "motion morphing, 120hz" look on my videos from a PC rather than letting a new LCD screen do the work. Not only do I feel the results are better than the TVs, but depending on your hardware, you'd be saving a lot of $$$. Now my friend Kevin wrote this script after I told him I wanted to buy a 120hz projector. He advised me to wait until he could find a software solution, and sure enough he did with some plugins and tinkering around. I'm going to paste you folks right here the settings I'm using. I hope it makes sense to some of you out there. Also I'd like to mention I'm using a e6300@2.8ghz to get very nice results in MPC. Also I am using the Haali splitter on the 720p MKVs. Boy do they look great. If any of you folks have better hardware, or tinker around with this script and find BETTER results, please let us all know!
Grab MVtools Here
Grab Avisynth MT Here
SetMtmode(2,10)
source=ffdshow_source()
source=changefps(source,source,true)
# assume progressive PAL 25 fps or NTSC Film 23.976 source
backward_vec = source.MVAnalyse(blksize=16, isb = true, chroma=false, pel=1, searchparam=1, idx=1)
# we use explicit idx for more fast processing
forward_vec = source.MVAnalyse(blksize=16, isb = false, chroma=false, pel=1, searchparam=1, idx=1)
source.MVFlowFps(backward_vec, forward_vec, num=2*FramerateNumerator(source), \\
den=FramerateDenominator(source), mask=0, idx=1)
distributor()
Grab MVtools Here
SetMtmode(2,10)
distributor()
