I finally have a Core i7 @ 3,8 GHz now and want to use frame rate doubling. What script/settings would you recommend for normal DVDs?
@all Core i7 users: What settings do you use and what work for you with HypterThreading (HT) enabled?
I already tried various scripts, but most of them crash when I have all 4 cores and HT enabled. I observed the following: With one script (one of 8:13 using mvtools2), I played arround with my i7 and noticed the following: If I disable Hyper Threading and disable 2 cores (so I have two cores in my Task Manager) it works quite well (even skipping works most of the times and DVD Menus also works "a bit". Things get worse if I enable all 4 cores but still work except that skipping is working less often and DVD menus do not work. As soon as I enable Hyper Threading too (giving my 8 cores in Task Manager) the script was only working about once out of 4 times or so and skipping did always crash the player.
@Delerue, What settings did you use on the AviSynth tab in ffdshow?
Before ya mention it the CPU runs COLD so it's not overheating.
