AVS › AVS Forum › Audio › Receivers, Amps, and Processors › ps3 -> yamaha v663 no surround sound
post #1 of 4
What I have done
5 speakers connected and working (2 f, 1 c, 2 r,1s)
1.Plugged hdmi cable from ps3 to receiver, and another hdmi cable to the display
2. ran the Yamaha auto audio setup program
3. turned on receiver, turned on ps3, turned on tv
4. setup all set to auto on ps3, with hdmi set as audio and video source
5. set yamaha input source to dvd, source type straight effect
6. HDMI box is lit up
7. video is working
8. audio is only outputting two channels, one to each front speaker!!
(no lights or indications saying it is receiving a dobly signal, although when I pull up the information on the tv,the ps3 data display says Dobly Digital, 5.1CH 48 KHZ 448 KBS)
any help?
post #2 of 4
also add i am playing a blue ray disc if that helps
post #3 of 4
Did you do the audio setup on your ps3 when it was connected straight to your TV or after you connected it to your receiver. If it was the former, do the audio setup on your ps3 again.
post #4 of 4
worked thanks!
