I've tried over the past several months to really like my Onkyo 875 paired with my Focal 826v's...but the combination of a bright receiver with bright speakers just leads to exponential levels of brightness I'm not ready to accept.
So I've spent some time looking at how I can replace my 875 with another receiver...specifically, the Yamaha sound has alway had a place close to my heart, especially when paired with Focals. But the news that the Yamaha receivers don't pass BTB essentially mutes the argument for that replacement. I've considered the Denon 4308, but then...
Now I'm thinking that I could just use my Onkyo 875 as a pre-amp since it processes everything that currently exists and buy a separate 5-7 channel amp (using a 5.1 setup currently). Unfortunately, I have little experience with separates outside of what I read here on AVS...so just to make sure, going from my 875's pre-out to a separate amp would be the ticket to changing the sound, correct?
Does anyone have any recommendations in the $1000-$1300ish price range? New or used.
I like the older H/K stereo equipment. Hope they take care of their issues. I heard that the new flagship will be in the $1,400.00 range. Hope it sound and works better then the 7300/745. You never know, I may buy one?
