AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Onkyo TX-SR606 Owners Thread
The Onkyo TX-SR606 Owners Thread - Page 52
post #1531 of 9415
Originally Posted by ioannisds View Post
Now that I've got someone else here with a PS3 and a 606, can you tell me if you get any kind of hum/buzzing sound when the PS3 is hooked up? Just go to the XMB, make sure a game or anything is NOT highlighted (so that you've got silence), and then turn up the volume. I'm on my 2nd 606 and both have the same problem, and now I'm not sure if it is an Onkyo thing, a PS3 thing, or some external noise in my wiring (that I am completely unable to isolate).
ioannisds, see my post above. Do you have Dynamic EQ enabled? There is a problem with Dolby digital sources and Dynamic EQ causing speaker hum with the 606.
post #1532 of 9415
I do, but the hum is present whether it is on or off, and regardless of whether or not it is a DD signal.
post #1533 of 9415
Some questions about the menu system on my new 606 I didn't see anyone mention in searching this thread (I admit it - I didn't read through every post :-):
I told it the TV is 16:9 (a Westinghouse digital LVM-42w2), but the menu almost always comes up
in what looks like 4:3, with the top of the top line of text clipped. The exception was when I plugged in the setup microphone - the system powered itself up automatically and came up in a 16:9 screen with no clipping going on, so it appears to be able to talk to the monitor correctly when it really wants to.
I haven't yet hooked up any alternate video sources and tried the up-conversion - I hope the upconverted images aren't clipped as well :-).
Anyone else seen these clipped menus? It isn't like it is a critical problem, but I'm just wondering if it is normal.
One definitely positive thing I have had a chance to notice: It deals with the "digital quality" sound dropouts from my Comcast scientific atlanta box a lot better that my old receiver, with the sound coming back very quickly instead of me having to poke the receiver with a stick.
Tomorrow I can spend the 4th trying to get my Harmony remote reprogrammed with useful screen layouts...
post #1534 of 9415
Originally Posted by Kris-Co View Post
Well the HDMI cables I'm using between the players and the receiver are just the ones that came included in the box with the players. However the one I have connecting the receiver to the tv was a cheap $12.99 HDMI cable I bought at Big Lots. Which would you reccommend? I surely don't want to buy one at best buy for $40-50. They can't really be any better can they?
Just order a cable off monoprice, they're cheap, and it'll suit your purposes. You can also try swapping the cables you have around. See if one particular cable is flakey.
post #1535 of 9415
Yikes. In that case I have no idea, and I can see how frustrated you must be. If it's only with the PS3 I'm guessing it's a ground loop, but that's a whole new can of worms right there. Good luck tracking it down.
post #1536 of 9415
Originally Posted by kplex View Post
Use Multichannel if you have 5.1, and PLIIx if you have 7.1.
Thanks sir! Much appreciated for quick answer.
post #1537 of 9415
Does anybody know if there is some sort of function that is set on that makes the Onkyo 606 warm even though it has been in standby mode for hours? or is this natural?
post #1538 of 9415
Funny you should mention that. I don't know what is going on inside the box, but after I checked the temperature for tivoboy with the 606 On (116 deg F), I left the probe in place over night, with the unit on Standby. When I got up this morning, the temperature was 104 deg F.
Since I have Control, Power Control and TV Control enabled, I think my 606 may be in a Ready state, rather than Standby, although it might revert to Standby when the TV is off. I'll play with this a little more today to see how much diffence in temperature I get between Standby and Ready.
In any case, the 606 must be drawing a bit of power even in Standby to get it up to 104 deg F. Anyone have a Kill-A-Watt meter to check this out?
post #1539 of 9415
It's probably because you have either HDMI control enabled or Zone 2 turned on.
post #1540 of 9415
As far as the sampling frequency, just hit the display button on the Onkyo's remote. It will cycle through the input with volume/surround mode/sampling frequency each time you hit it.
Hmmm, all I get when I hit Display repeatedly is Dolby D 5.1/CBL Dolby D. That's with the input set to the HR21.
Also, make sure you go into the sound options in the PS3 menu, select HDMI as the output, and let it automatically detect all of the speaker combinations/sampling rates that the Onkyo can handle.
Yep, my PS3 is set to HDMI/Auto.
This morning, my buzz is worse than it was last night. I can't imagine why, since I didn't change anything. Now, I can hear it from 6 feet away at a volume level of 31 and higher. With my ear on the center speaker, I can hear it down to volume level 18. This has got to stop! While I was checking out the audio output setings I did notice that the buzz went away completely when I pressed the X button to save the settings. The speakers went completely silent for just a moment.
EDIT: I tried this again, but this time with a BluRay disk playing. During the silent parts of the video, I turned the volume up to max and heard no hum. I seem to only get the hum when there is no disk playing. Is this true for you, ioannisds?
post #1541 of 9415
I have read about half of the posts on this long thread. I am considering the Yamaha 663 or the Onkyo 606. I have had nothing but problems with the Onkyo TX-SR502, after the first year I owned it. I bought the Onkyo 605 and the center channel was bad from day one and I returned it. I must be crazy to even consider another Onkyo, but the price and features are tempting. My 502 worked great the first year and then it was a series of problems. I know Yamaha will last and they are built like a tank, but I can't get long term free finance terms(no interest)that I need right now. I see that Denon is coming out with a new unit that will retail for $649, the AVR-1909. It has 90X7, Dolby True HD and DTS-HD MA decoding. It also has 3 HDMI inputs, but I have no idea when it will be available and what the "street" price wil be . I have a CC account(they have never screwed me)and they will probably carry this receiver, but when is the question. I just recently purchased the Panasonic BD 30 and I love it, but want the benefits of the improved sound on Blu Ray. I have it hooked up to a Panasonic Plasma(love it). The problems with Onkyo don't always surface right away, that's my concern. Even with an extended warranty, I'd have to unhook and re-connect all my equipment every time I have a problem. Anybody have any advice for this newbie. Thanks!
post #1542 of 9415
Heat is one of the long-term issue in electronic which you don't see right away. this is one of the reasons why I am also considering Denon. the main reason I like denon is Audyssey Dynamic volume.
I'll wait until Denon 1909 is out with some reviews. Then I will decide whether to get Onkyo 606 or denon 1909.
post #1543 of 9415
I'll give this a shot and post back. I too noticed what you mentioned about the X button when I was troubleshooting. It is just bizarre, and I'm wondering if it hasn't been mentioned a ton in this thread because it might be an issue with the PS3... I hope not, because I love that damn machine. LOVE IT . Oh, and make sure you hit display when the PS3 is on. You are getting the information for your cable box with the info you posted.
EDIT: You are right Bugs. I put in 300 just now, and the hum was gone while the disc was paused, even at maximum volume. There was some negligible (and what sounds like "normal") noise at that volume level, BUT NO HUM. I switched through the sound formats (DD, True-HD, and Linear PCM), and still no hum. What is interesting to me is that this is happening when the soundtrack is encoded in 5.1 surround, and not 7.1. I wonder if we are getting this buzzing sound because of something going on in the down-mixing of 7.1 LPCM (like when you are viewing the XMB) to a 5.1 speaker set-up? Seems weird... I still might give a better HDMI cable a try, but now I'm pretty sure it is not a ground loop issue, as ground loops don't really care if you are listening to mono or effin' 12.1. I'd be curious to find out if ALL of the people having issues with this buzzing (605 and 705 owner's included) have a 5.1 setup. I wish I had a couple of extra speakers sitting around to hook up and see what would happen with 7.1 going into 7.1 speakers.
EDIT part the 2nd: So I turned off all 7.1 surround options in the PS3's audio setup, went back into the XMB, and cranked the volume. Even with everthing set to 5.1, the buzz was still there, though at a level lower than when the Onkyo was receiving 7.1. My head hurts. I just don't know what to make of this, but it is starting to look like our PS3s have some funkiness going on. If it were a problem with the Onkyo, I don't think we'd be able to change or eliminate the hum like we have been doing. 5.1 multichannel LPCM at 48khz coming from the PS3 while in the XMB isn't any different (as far as the AVR is concerned) from the same format coming from a BD. What is nice to know here is that when watching movies, it is not a concern. But I stream a lot of video from my PC and game, and it kinda sucks to have that issue when doing either of the above. Though I will admit I don't ever do either of those at reference levels or anything. I guess time will tell if we get this solved or not.
post #1544 of 9415
I was also going between the 663 and 606 i decided on the 606 because mainly of the 4 hdmi's vs 2. Im glad i did it sounds fantastic. for 349 i think its a great unit for the price. Whatched a blu ray last night and it sounded great. MIne gets a little warm but not any hotter my older HK got. I dont think youw ill be disapointed with the 606.
post #1545 of 9415
Team,
Looking for some help here. I am setting up my father in laws Home Theater and when I was playing the Blueray SpiderMan 3 on the Sony BDP-S300 via HDMI 1.3 thru the TX-SR606, I can't seem to get the receiver to detect TRUEHD. I've validated the players audio settings was set to digital not PCM as the players manual suggested, but I don't even see the option come up as I cycle thru the listening modes. I do indeed have a 7.1 speaker setup, correctly setup via the Audessy setup. I can select the Dolby Movie IIx and all other Doldby modes (EX, etc, but no TRUE HD..) which is 7.1 with no issue.. I wanted it to be set as DIRECT and autoselect the proper mode.. What am I missing? Any information you may need please advise...
THANKS,
KEYMIX
post #1546 of 9415
Originally Posted by KeyMix View Post
Team,
THANKS,
KEYMIX
I'm not familiar with that particular BD player, but are you sure it can send bitstream audio to the Onkyo? I ask because I know on my Playstation 3, it cannot send a bitstream to the AVR, but rather does the decoding itself, and then sends the decoded True-HD or whatever signal to the 606. If your BD player functions in the same way, you will NOT see any True-HD logo or anything, as the Onkyo is not decoding the signal, but rather the player is. If this is the case, make sure the Onkyo is set for multichannel 7.1, and you will in fact be ouputting the HD audio track (even though the receiver doesn't say so). Good luck.
post #1547 of 9415
Hoo boy... my first A/V receiver and now this buzz with the PS3 (my BluRay player). I got mine yesterday after seaching around for a decent unit. Hooked it up and was pleased with everything. Then I fired up the PS3, going into HDMI on the A/V receiver and the first thing I noticed was the buzz. Its similar to ground hum.... so I lifted the ground on the power strip.
Its still there. I have the audio on the PS3 set to "auto". Now, here is the bad part. I also have a Toshiba DVD player (with HDMI) so I tried that in HDMI port 2 on the 606. Well, it played a CD fine, but when I played a DVD, there was buzz in the signal.
This is telling me its NOT just a PS3 issue. There has to be some weird thing going on when you play audio coming in through the HDMI ports on the 606. I like the unit otherwise, but this might have to go back.
I will be experimenting over the next few days trying a few other things. Please, those of us who are getting buzz "hum", similar to grounding hum (60 Hz and overtones) when using audio through HDMI, please post your results.
post #1548 of 9415
Team,
THANKS,
KEYMIX
An S300 doesn't handle TrueHD or DTS-HD at all. It can't decode them as a PS3 does, and it can't send the undecoded bitstream. It's a very basic Blu-ray player.
post #1549 of 9415
It is so good to hear that we are not alone here . Try this for your Toshiba buzz: turn off the Dynamic EQ (hit audio on the remote, scroll through until you get to it). Apparently this is a known issue with Audyssey and DD soundtracks, and from what SeriousHorse has said, Onkyo Japan is aware and working on a fix. If you turn off Dynamic EQ and still have the buzz with the Toshiba, then I will be having some serious mixed emotions, as my PS3 is probably ok but my 606 is pooping all over itself. Please let us know what happens!
post #1550 of 9415
I have the 606 connected through HDMI to a Magnavox Blu Ray player, a Comcast HD DVR; a Toshiba A2 HD DVD player and a Toshiba DLP TV. I have the Dynamic EQ turned on and no buzz from any of the components at any volume level.
Cables are all Monoprice HDMI cables - 1.3 certified.
Just posting to let others with the buzz problem know that it is not a universal problem.
post #1551 of 9415
Thanks for your reply... Can I ask you a quick question b/c I may have had a BASIC misunderstanding of what TRUE HD was.. I saw another post in this thread that referenced TRUE HD like nothing more than a 5.1 wrapper or a zip container of somesort.. I was understanding TRUE HD as a an actual Dolby Decoder for 7.1 format.. If I am understanding your comment above..if my player or like the PS3 works is decoded TRUE-HS to what ever the signal was.. does that mean if I am set to DIRECT and receive a simple Dolby Digiteal logo in RED... That it's really a 5.1 track?? Makes sense.. SpiderMan3 does say TRUE HD 5.1.. Thanks...
post #1552 of 9415
Thanks kplex... So if I am HDMI 1.3 to the S300 to the AVR and I am set to let's say Dolby Movie IIx. What am I actually getting from the Blue Ray, a 5.1 signal upconverted to 7.1 by the SR606 via Dolby Movie IIx?? Is this my best choice?
post #1553 of 9415
You should be selecting the Dolby Digital (or DD+) tracks on the disks, and that's what you should be receiving. You can press the Display button on the 606 remote to see what you're receiving. Once you're sure you're receiving the right audio format, use PLIIx to matrix the signal to 7.1, or DD or DD+ to hear the original.
post #1554 of 9415
True-HD is, if I understand it correctly, an uncompressed, lossless audio format, where Dolby Digital is a lossy format (though still very good). I think of it as being the difference between an mp3 and a wav file. If you are seeing the red DD logo, then the player is sending the soundtrack as Dolby Digital, NOT True-HD. What you might have to do is toggle through the soundtracks on the disc until you get to True-HD (which is what I have to do with my PS3, as it defaults to DD). I would also do a little research on your particular player. From kplex's comments above, it sounds like the player might just be outputting plain old DD or DTS instead of the HD audio formats, and in which case you will never be able to get True-HD out of it. If the player is set to direct, then in all likelihood the receiver is decoding the DD signal (which is why you get the DD logo), and if you set the player to PCM, the player will decode the soundtrack. But if the player can't handle HD audio, you are out of luck no matter what you do, and are stuck with the regular DD or DTS formats . Hope this helps.
post #1555 of 9415
Ok guys I found the culprit setting, I when into menu 7-5 and turned off "Power Control" to disabled and the unit was ice cold in standby mode. I will leave it like this since I do not like the fact that the unit is hot 24/7.
post #1556 of 9415
I played around with my digital thermometer last night and today and here are the results.
My 606 is on an open shelf with 8" clearance on the sides and 5" on the top and back. No fan. I placed the temperature probe on the hot spot 9.5" in from the front and 2.5" in from the right side. I took the readings over a two hour period for each condition.
  • Ambient room temperature: 78 F
  • Standby: 85 F - 86 F
  • Ready: 103 F - 107 F
  • On, volume level = 26: 119 F - 120 F
  • On, volume level = 50: 122 F - 123 F
  • On, volume level = 70: 126 F - 129 F
post #1557 of 9415
Well, I've been fooling around with the upconversion, and don't notice any clipping there, so it is really just the menu title being clipped in each page, which looks ugly, but doesn't hurt anything.
On the other hand, I'm not sure I'm going to use the upconversion for anything since the picture always seems better if I let my monitor do whatever it does with lowres sources (not that plain old NTCS looks very good no matter who is blowing up the image :-).
post #1558 of 9415
Originally Posted by get_zwole View Post
got mine all set up and ran audysey earlier. All in all im very happy for a 349 dollar receiver. The audysey put my ascends as full range so i had to tweak the crossover a bit but it sounds great. Im glad i got it because of the 4hdmi's too i have three now and will be getting a sacd dvda player within the month so that will take up the last one. So far i am very happy gonna watch a blu ray in a bit see how she looks on there.
May I ask where it can be found for this?
100th post
post #1559 of 9415
Close. Both Dolby Digital and Dolby True-HD are compressed. However, True-HD uses lossless compression. It makes the file size of the audio smaller, without losing any data. Dolby Digital compresses, but uses lossy compression, so data is lost.
post #1560 of 9415
Thanks for the post, aydu. It's good to know this is not a universal problem. I wonder what the differences in our set ups are, why some of us get the buzzing and others don't?
