Originally Posted by drfruit
Would it not be better for those affected to start a separate thread about the hum/buzz problem in 606's?
I have just tested it by pausing several dvd's (Dolby 1, 2.0, 5.1 and DTS) on my PS3 and turning the volume to Max. Even with my ear to the speaker, I hear nothing. Then I remembered, someone wrote that it only occurs on 1080p systems (mine is 1080i). Do I need to use bitstream or PCM, DD sources and non-DD sources? A 7.1 or 5.1 setup? A disconnected sub? A 5.1 system tricked into thinking it is 7.1?
I have followed this thread from the start, but I lost track of what is or is not required to hear the unwanted noise. A separate thread with a startup FAQ might save a lot of confusion and repeat posts.
I can cause the humm/buzz by doing the following. Start the PS3 and make sure the audio is PCM (not sure if you have a choice here). Sit on an item in the XMB (main menu) with no sound and crank the volume up. The buzz is there.
Using a DVD, make sure the PS3 is outputting PCM and pause the DVD of BD and crank the volume.
I have a 1080p set and 5.1 setup with sub and this happens every time.
