AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official 9G Pioneer General Discussion Thread
The Official 9G Pioneer General Discussion Thread - Page 267
post #7981 of 7984
Originally Posted by bodosom View Post
You missed the point. The bottom speaker televsion stands have taller posts so there's room for the speaker. You can use a side speaker television or monitor stand if you remove your speaker. All modern Pioneers have the same bolt patterns and sleeve dimensions given the same screen size.
Doh! Well, it'll fit, at least!
I'm in Florida, guys, I appreciate the gestures, though. Just ordered the TS02PM through Amazon in any case.
post #7982 of 7984
Any idea on how I can check the hours on my KRP-500M easily?
post #7983 of 7984
I have a Pro-111FD. Can I get a 6020 calibrated to be close to it?
post #7984 of 7984
Check out this thread:
http://www.avsforum.com/t/1226671/is-it-possible-to-turn-a-6020fd-into-an-elite
For about $100 you can turn your 6020FD into a PRO-151FD which is the 60" version of the PRO-111FD. Then you can contact Turbe at ControlCal to get a program to unlock the ISF modes.
http://www.controlcal.com/forum/index.php
