AVS › AVS Forum › Audio › Speakers › The OFFICIAL Emotiva Speaker Owner's thread!
The OFFICIAL Emotiva Speaker Owner's thread! - Page 17
post #481 of 571
Originally Posted by joeyvaz View Post
One time the sub came up as being 30 ft. away which is the max. And it is only 12.5' away. I know it isn't my technique as I've been using auto calibration in various forms for many years.
The Audyssey technique is unique to Audyssey in various ways. I'd recommend the Setup Guide linked in the first post of the Official Audyssey Thread here on AVS.
And using the quick calibration yields the same results of less than stellar bass.
I'd expect anything less than the full number of mic positions to produce a poor result.
Out of 12 or so times, only once did the bass sound as it should. Both my Elite 94 and Elite 23 works flawlessly each time.
What do you mean by sounding "as it should"? Are you experienced at listening to flat bass? Many people become accustomed to lumpy bass and when they first hear Audyssey's very flat bass they often think something "is missing".
For multiEQ, i moved my couch away from the wall, put the mic on a tripod first at the far left corner which is my main listening stop, moved it 3 ft to center, 3 ft again to the right (all along the back wall about 18" from the wall.
That sounds OK (I assume you mean the far corner of the couch not the room?) And the mic is at ear height and pointing up to the ceiling?
The next 3 spots were in front of the couch in the same three relative locations to the back (left side of couch, three feet over, then another 3 feet over.) Not sure if anything in my technique is causing this. If you see anything, please comment. Thanks!!!!
That does sound OK - the MLP and then 2 other positions on the couch with the mic about 2 feet from the back wall and three more spots mirroring those but 3 feet in front, is more or less how I do mine. I then use the remaining two spots to 'fill in' around the MLP (I care more about the MLP than getting a smooth sound over the entire room as I am either listening alone or with my wife, who doesn't really care too much about the SQ
But there is something wrong here somewhere. How are you setting the sub prior to running Audyssey? It needs to be set to deliver about 75dB from the MLP (bear in mind the usual SPL meters don't work too well with subs and can give readings several dB off).
Which flavour of Audyssey does your AVR have? Is it XT or plain MultEQ? I ask because you mention 6 mic positions which is what MultEQ offers IIRC.
It might be worth taking this over to the Official Audyssey Thread and seeing what the other guys there think - I;m running out of suggestions (assuming you have a good mic).
post #482 of 571
For multiEQ, i moved my couch away from the wall, put the mic on a tripod first at the far left corner which is my main listening stop, moved it 3 ft to center, 3 ft again to the right (all along the back wall about 18" from the wall. The next 3 spots were in front of the couch in the same three relative locations to the back (left side of couch, three feet over, then another 3 feet over.
Are you moving your couch out of the way to take your measurements? Hard to tell by your description, but if so, that should not be done. The couch needs to be in its normal position as it will impact standing waves, particularly near a boundary. Also, what do you mean by "far left corner"? Is that referencing the room or couch?
post #483 of 571
Yes, I do move the couch forward about 3 feet to do the first 3 positions. This is so the mic is on the tripod at the main listening position and standing on the floor and not on the couch itself. I believe I read this in the Audessy thread. I move it back against the wall to do the last three positions which are in front of the couch. For what it's worth. I did the calibration 5-6 times with the couch against the wall and the tripod on the couch itself. I still get the same results with the bass issues. So I know that moving the couch isn't the issue.
I've read the thread after experiencing these problems. I've followed the suggestions as best I can.
I’d expect anything less than the full number of mic positions to produce a poor result.
6 positions in my listening area seems fine when it did work that one time.
By sounding as it should I mean that the sub doesn't bottom out and make VERY strange sounds. I have two ED A2-300 subs in my two setups for the last three years or so. I know exactly how they should sound: nice, deep, full bass that blends in well with my music. And basically undetectable in movies scenes. Easy for me to tell if they are configured correctly with two movie scenes: Sewer scene in Battle Los Angeles add First action scene in GI Joe. Laser guns that have DEEP bass with the shots. When working correctly and with my Elite receivers, those are two of my favorite scenes to show off my system.
Yes corners of the couch, not room.
I've set it to 75bd as per the first instruction on screen. I go by what it says on the screen while I tweak the gain on the sub. I've also tried it with the on screen reading saying 70db and another time at 80db. Same results during those same two bass heavy scenes.
MultiEQ.
I'm going to do just that after I call Onkyo tomorrow and get a new mic. If I get the same results I will definitely post in the Audessy thread.
post #484 of 571
Both of those things can skew your results. It may not be the cause of your problem, but a problem nonetheless. Putting the tripod on the couch can cause distance anomolies with Audyssey due to conduction/vibration in the lower octaves. As well, your couch can act as a bass trap against the wall and moving it can cause significant differences in the FR. You should use a tripod with a boom arm so you can take the measurements with the couch in place.
post #485 of 571
@joeyvaz - +1. A lot of use something similar to this:
http://www.amazon.com/Stage-Stands-7.../dp/B000978D58
post #486 of 571
Thanks Keith. Ordering one now on ebay. How do you connect the mic to it? Is there a threaded collor on the end? I'm thinking I can take my tripod's mount off and clamp it on the boom mic and make sure it is pointing up.
Just ordered a new mic from Onkyo. I had to pay since it was more than 30 days since I purchased the unit. Wasn't too happy that I had to pay, but thankfully it was only $18.63. I'm working in NYC starting tomorrow so I'm going to stop at BH Photo and pick up a boom mic. Hopefully this will solve my problem once and for all. After that, a new new XPA-5 will be ordered right after the holidays.
post #487 of 571
Sorry - forgot to add you also need this
http://www.amazon.com/s/ref=nb_sb_ss...ix=on+stage+cm
to connect the mic to the stand.
post #488 of 571
Looking for two ERM-1's please PM me if you have them and are looking to sell. Thanks.
post #489 of 571
Got a new mic in the mail today. Pretty much the same results...bass bottoms out on a couple of scenes. Especially when a laser gun is shot. And in order to get 75db on screen with Audessy, my gain on the ED A2-300 is at roughly the 6-7 o'clock position. I think that is way too low. On my Elite receivers, I remember setting it around the 8-9 o'clock position, but they are two different calibration setups so that may be why. Going to put this in the Audessy thread to see if I find other suggestions. Thanks for the time and effort trying to help me sort this out.
Joe
post #490 of 571
I have 3 new ERM 6.2 speakers available for sale if anyone is interested...?
post #491 of 571
Can anyone tell me more about the extension toggle switch on the 6.3? There is no mention of it on the 6.3 product page.
Joe
Found it in the manual. Now to experiment with the different setting on the 6.2/6.3 combo....
post #492 of 571
Is there anything that can be done to prevent the grills from falling off so easily? I mean, you barely brush up against them and the slam to the floor. Much stronger magnets should have been used.
Has anyone modified them yet? If not, I will take a measurement and see if I can find some stronger earth magnets and try to make it work.
I'm going to put a call into Emo tomorrow and see if they have any suggestions...
post #493 of 571
My bro-in-law just got his 8.3's and asked a quick question..Why do the 8" woofers measure 7" diameter and the 5.25 speakers measure 4.25? Also he has to call up the company because on of the grill covers has bunched up cloth below the Emotiva emblem instead of pulled tight..thanks in advance
post #494 of 571
Are you measuring the cone area or from the outer edge of the surround to the opposite side's outer edge? That's the only thing I can think of. I'm sure they will send him a new grill if the cloth came bunched up. Not so sure they can do anything for my weak magnets. They are probably the same on all the grills. Do his grills come off easily?
post #495 of 571
Measure to the outside edge of the basket.
post #496 of 571
Joe, do you have an older set of speakers?? I can't recall which you have. Way back, the magnets were weak but Emo changed them at some point. All the magnets on my 6.3s and ERD-1s are very strong indeed. If you have older speakers with the weaker magnets, if you speak very nicely to Emo they may be able to help you out, as this was acknowledged by them to be a design fault.
post #497 of 571
Hey Keith,
I just got these as an early Christmas present from the wife. So they are new. But maybe I was sent the old style grills? Who knows, but these things fall off ridiculously easy. I spent the whole weekend telling my family and friends to be careful with my speakers during our poker game, lol.
I'm calling them in a couple of hours and see what they say. Velcro at the corners will help if they don't stand up to their product's issues.
post #498 of 571
Hey Keith,
Odd thing then. They definitely had a problem some while back - I recall a review of an early sample of their Reference line speakers and the reviewer commented on the weak magnets. He said he had spoken to Emo who said they would address the problem. That was ages ago. I can tell you that mine are very firm indeed and take quite a tug to remove the grilles - there is no way they'd come off just by brushing against them, so it seems there is something odd about yours. I'm sure Emo will help you out here - and you can tell them that you have spoken to others who have their speakers and who say their magnets are much stronger.
post #499 of 571
Joeyvaz: 1st , magnets are pretty strong, no problem with the grills falling off. 2nd, I think the extra inch is on the inside of the speakers not showing from the outside, since the woofers are mounted from the inside..The speaker opening measures 7" ( I remeasured myself yesterday when I visited him)..Great sounding speakers using an Anthem 2 channel amp pushing them.
thanks again for all the replies..
post #500 of 571
Spoke to Emotiva and sent them some pics. While on the phone they suggested that I back out the screws that hold the aluminum baffle onto the speaker. These screws are what make contact with the magnets on the grill. While I had him on the line, I noticed the screw heads were really recessed, scratched, and some were rounded over. So much so that the allen key wouldn't back it out!!! I told him this and I also stated that I didn't want to back them out so much to make contact and risk having the baffle vibrate while listening to the speakers loudly. Legitimate concern, wouldn't you think?
I put this all in an email with hi res pics. I even sent a pic of a cracked grill frame that I just noticed!!! Not happy with quality control at this point. I hope I didn't get refurbed speakers at full (clearance) pricing. That would NOT be cool or acceptable. I will see what their response is and keep the thread informed.
*****Can anyone who owns 6.2s confirm: 1. Are the screws recessed into the aluminum baffle? 2. Or are they flush with the aluminum baffle? 3.Are the screw heads scratched or rounded over?
Thanks!!!!
post #501 of 571
Thanks!!!!
I just went and checked my 6.3s for you. The screw heads are more or less flush with the aluminium baffle. They are not scratched in any way and definitely not rounded over. When you say 'rounded over' I assume you mean they look like the wrong tool was used to tighten them? Definitely not, here.
Backing out the screws may make the magnets work better - but when you do it, do the baffles then become loose? If so that isn't an acceptable solution (longer screws would be). There definitely seems to be some QC issues there. As they don;t affect SQ in any way, maybe a nice further discount would suit you?
post #502 of 571
Backing out the screws may make the magnets work better - but when you do it, do the baffles then become loose? If so that isn’t an acceptable solution (longer screws would be). There definitely seems to be some QC issues there. As they don;t affect SQ in any way, maybe a nice further discount would suit you?
Yeah Keith, either the wrong tool, a worn out one, or even user error can round out an allen screw. This is how mine look. They look like absolute crap to be honest. Not even looking for a further discount, I'd prefer they send out a new set of speakers actually. That would suit me much better. I'll post their response as soon as they reply. Hopefully it will be taken care of promptly and the way it should: make the customer happy.
I hope they do the right thing. I have a Def Tech Mythos set up in my main home theater that I was considering swapping out to all Emo gear after the holiday. Got the blessing from the boss (wife) and all!!! But only if I feel this MUCH less expensive matter is handled accordingly. I mean, I'm not going to invest $5-6K in a new 7.2 setup with one company if they can't take care of me on a $400 pair of book shelf speakers that I received in unsatisfactory condition. Just the way I do business, but we shall see.
post #503 of 571
Agree totally with you. Be sure to let us know how they take care of you.
post #504 of 571
Here are some of the pics I sent to Emotiva. They show a cracked grill frame, recessed screws, rounded over and scratched heads, and one of some glue like substance on one corner of my 6.3 that's being used as a center. To me, quality control was lacking on these units. Thank God they sound great. But I could never have the grills off to have them playing naked. The flaws would bother me immensely.
post #505 of 571
Not to forget: these are NEW! I ordered them last week of November, received them the following week, I went to Hawaii for two weeks before being able to open and inspect them. And they have been playing now for less than two weeks only.
post #506 of 571
When you unpacked the speakers, was there a very thin foam cloth between the grille and the aluminium baffle?
post #507 of 571
No there wasn't Keith. I just double checked the box (I keep everything from my electronic equipment) and there was nothing there. Just the black cloth bag and the manual and foam strips.
post #508 of 571
Hmmm. My speakers came with a thin foam 'cloth' between the grill and the baffle. I am guessing this is there to stop the grille moving about during transit and possibly marking the baffle. If yours did not have this protection, then I am wondering why. Perhaps others might chime in here and tell us if their speakers had this thin foam protection? It may be something they only do for export (I am in the UK) or they may have done it at one time and no longer do. I am about to go into my attic to retrieve a subwoofer, so I will double-check the 6.3 packaging while I am there. I keep it all, like you do.
EDIT: Joe, I may have given you a bad steer here. I just checked for you and there are no foam cloths in the Emo speaker box that I looked in. I did only look in one as it was difficult to get to the others and sometimes I do store all the bits and pieces in one box if there is a set of two or three. So now I can’t be sure - but I do remember it this way. Before you use this info to talk to Emo, I'd double check with some of the other owners of Emo speakers, to be on the safe side. Sorry about that.
post #509 of 571
Is anyone using their ERD-1's as front height speakers? I have a pair as side surrounds and love them. I was thinking of getting another pair for front heights with the clearance going on. But I wasn't sure how bipole or dipole would be for that application. Anyone have experience with this?
post #510 of 571
Yes, I do. I use them in bipole mode.
I initially experimented with height channels using a cheap pair of direct radiators that I had lying around. These worked remarkably well. Later I started using the ERD-1s in bipole mode and these seem to work well also. I used to favour DSX for height channels but now favour PLIIz and it may be that PLIIz is less demanding of its speakers - I don't know. But the ERD-1s seemed to work with either method. According to Audyssey, one should use direct radiators but I did ask Chris Kyriakakis and he said that bipoles would "probably be OK".
The reason I started using the ERD-1s is that, a) I had a spare pair and b) I wanted height (and surround) speakers all from the same manufacturer so that I could be sure they were all voiced similarly. In my room it isn't practical to use a pair of 6.2s as height speakers as they are too deep, hence my choice of the ERD-1s.
I think, on reflection, that any decent set of small direct-radiators, designed for wall mounting, would probably give a good result though.
  Back to Forum: Speakers
