Originally Posted by
casey.christian
Thanks for your posting! Do you know if anyone else has experienced these problems with their TV? If so, is it only a Mitsubishi thing or does it happen with other makes as well? Please provide me with links if possible to other user's postings about this.
If not, I'll add your bug as reported by one person tomorrow. Thanks!
-C.
I haven't been able to find anyone else with the issue, but of course I haven't been able to find anyone with the same TV that doesn't have the issue either. If someone has the same tv with no problems, then I may be able to narrow the solution down.
But I can say it is not a random thing, it happens 100% of the time, at the same time. So I'm not sure if it is a simplink signal, or if it is a handshake conflict.
For all I know it could be a signal being sent from the BH that is conflicting with the TV which is forcing a shut down, which of course can't be good.
So what I do , just in case, is leave the TV off until the BH has fully booted, or leave the TV on a different input during the boot up.
The Mitsu does not diplay 720i or p , so I'm wandering if the TV is protecting during the AUTO 720 scan, so to attempt to correct it I turned the AUTO resolution to 1080i, which did not work. So that could indicate that the forced resolution setting on the BH is not functioning correctly, and the BH is still AUTO setting. ANY IDEAS??? Does any on have the same Mits series TV?
THANKS....
