AVS › AVS Forum › A/V Control & Automation › Remote Control Area › comcast remote codes for toshiba tv
post #1 of 8
i have a toshiba theaterwide sd tv and i tried the codes comcast recommends; 0154, 0156, and 0060, with no luck. the remote does not flash twice when i enter a 4 digit code like it is supposed to. if you have any help i'd really appreciate it!
post #2 of 8
Does it flash one long flash, or not at all. If it doesn't flash at all, you may have a version of the remote that takes 5 digit setup codes. Try the codes again with "1" in front of them, i.e. 10154, 10156, 10060. If one of the codes work, but you are missing some functions that you need, there is a way to those. Post which one at least gives you some functions.
If it gives you one long flash, it means either that code is not built in, or perhaps you have the device for TV button set to a different one. There's a way to change that back, if that's the case.
post #3 of 8
when i do the four digit codes, it just flashes a regular flash like when you push any old button. when i try the five digit codes, it does one long flash. it is a new remote we got today to replace a broken one, so it has never been set to anything AFAIK.
post #4 of 8
the three digit code, 991, that is supposed to help you search for the code, does make the light flash twice if that helps...
post #5 of 8
oh i figured it out, thanks for your help! my remote does take 5 digit codes, but the first digit for tv codes is 1. thanks again!
post #6 of 8
the suggestion from kubakai worked for me. I had the same problem as razorjane. Interesting that they don't state that in the manual.
post #7 of 8
hey 10156 worked for me but not all the buttons work (channel - & + and the "onfo" button) if you've got anything on that i would be gr8full! biggrin.gif
post #8 of 8
What model TV? HERE are several discrete codes for many recent Toshiba LCD models.
Edited by mdavej - 4/16/13 at 11:54am
  Back to Forum: Remote Control Area
