AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › help: 1080p from PC on Westinghouse LVM-42w2 is shifted upward
post #1 of 3
Hello,
If this has been answered elsewhere, or should be better posted elsewhere, my apologies; I really did try to research it.
I have a Vista Media Center PC with a ATI Radeon 2400 HD connected to my Westinghouse LVM-42w2 via HDMI. 1080p images from the computer are "shifted upwards" by about 6-8 pixels; if I look closely, I can see a thin black border at the bottom, and I can tell that a few are missing off the top. Sides are fine.
Any other resolution from the PC has the same issue; however, the 1080i output from my TiVo HD is fine, and does not have the thin black border across the bottom.
I have looked into the 42w2 service mode to figure out a way to "move" the picture, and likewise have looked for a setting in the ATI Catalyst utility without success.
Does anyone have any ideas if anything can be done here?
post #2 of 3
I have a 42w2 v1.00 and my DVI 2 is affected by the same issue you explained. The bottom 6-8 horizontal pixels (11,520-15,360 total pixels) are the color of the bottom right pixel. I have used DVI2 before with my Vista PC and the pixel issue ceased to exist. I uninstalled Vista for XP and when I booted into XP for the first time I noticed everything had been pushed up like you said. I could clearly see the top 6-8 pixels were now cutoff. Eventually I thought to use DVI1 to determine the oddity. I am currently using DVI1 since I have all 2,073,600 pixels active. HDCP worked with my 360 HDDVD external drive in Vista through DVI2 just fine but with DVI1 it does not. I need to manually cycle signals frequently when changing resolutions, which is annoying since I play many games and watch HD videos often.
I don't know what else to tell you besides use DVI1 or try HDMI. I use VGA for 360 and component for PS2/HDSTB without any issues. Games and movies on 360 with resolutions of 1920x1080 pair up great with the native resolution of the Westinghouse. It is nice to have 1:1 pixel mapping while using a PC. I am a little worried about when I pick up my PS3 on June 12 and use HDMI since there are some issues, which I believe have since been fixed from the PS3 firmware. Then I can benchmark BD via HDMI and HDDVD via DVI to calibrate my 42w2 to the best of my ability.
post #3 of 3
Thanks for the response. In my case, the issue is happening over HDMI, but I haven't yet tried either DVI. I'll do so. (Also, my 42w2 is also a 1.00.)
You might be able to get around the HDCP issue by using Slysoft AnyDVD HD. I
Does anyone know the possible cause of this "pixel shift"?
