It appears the old Packard Bell Fast Media IR remote with IR receiver is the Rodney Dangerfield of remotes for media PC's- it gets no respect:
http://www.mythtv.org/wiki/index.php/PackardBell
"LIRC recognizes the receiver using the lirc_serial kernel module and everything proceeds by the book. However, the receiver sensitivity is poor and the remote needs to aimed dead-on to get accurate results. Overall, the setup is not very usable, and I had to throw away this receiver and remote and start from scratch"
The lircd config file generated in Mythbuntu 8.04 says the same thing in the comments, I assume from the same guy who wrote the file.
In my experience the past several months, this remote and receiver has performed nothing like described. I suspect the bad remarks were the result of bad batteries, IR interference from lights or a plasma screen in the room, the use of a random remote that didn't come with the IR receiver, or some combination of these.
I have had excellent results re: responsiveness, range and off axis sensitivity, at least using the remote that comes with the receiver with Geexbox and Myth.
I have had such good results that I've bought a couple of lots of 10 from partsparadiseinc on ebay (search "fast media remote"). Incredible deal for ~$3 per remote + IR receiver. I plan to deploy a *lot* of Geexboxes and Myth boxes for myself, family members and coworkers over the next year or so
My only gripe is the default key mappings and button assignments for Myth. Several buttons are unused when they could be used for transport control (i.e. fast forward/rewind), no Escape key equivalent and other issues with the default mapping.
Yes, I'm aware of the config files and could edit them manually, but to save time, I was wondering if there was a good GUI tool to configure Lirc remotes for Myth, and/or if anyone has alternative lircd remote button maps for the Packard Bell remote they'd like to share.
.My only gripe is the default key mappings and button assignments for Myth. Several buttons are unused when they could be used for transport control (i.e. fast forward/rewind), no Escape key equivalent and other issues with the default mapping.
