Here's a good question to keep in mind. When you are buying an LCD with a size and picture quality features, how would you know what to look for on the audio side of things? I know that there's a ratio measurement that you need to know about to match audio quality with the screen size. I'm still wondering how the ratio works. Let's say, if you buy a 46" Sony Bravia, what should the wattage of the home theater system be to match up with it? 600 watts, 800 watts, 1000 watts, etc...? That's something that is usually never considered, but experts do in fact know how to match audio with video.
AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Screen size to audio wattage ratio, how should I measure?
AVS Top Picks
