My fellow home theater enthusiast has been trying to talk me into doing something about the state of my bedroom theater at some point. Here's what I currently have set up.
Mitsubishi 46" CRT Rear-Pro
Yamaha RX-V1600 Receiver
Panasonic RP-61K DVD Player
DirecTV HR-20
5.1 Yamaha speaker system circa 1998
What began as a quest to replace my 480P/1080I behemoth TV with a Panasonic plasma has gotten... more complex. In an effort to make the room more elegant we've decided to wall mount the TV and move all the components into the bedrooms walk in closet.
Now, I could just mount the Yamaha speakers on the wall. Or I could go with some in ceiling mounted speakers. I like the idea of in ceiling speakers as it's less obtrusive and will be easy to wire as the bedrooms ceiling is the attic.
So I'm narrowing the plan down with my installer. Here's what we're thinking.
Equipment List
Three KEF Ci200.2QT's, one front left, front right, and center channel.
Two KEF Ci160.2QS's for my rears.
Panasonic TH-50PX80U Plasma TV
Oppo Digital 980HD DVD/SACD player.
And some tiny 8" sub mounted under the bed. TBD
Install
The front's will be wired in Music Mode so they come down when they receive an audio signal from my Yamaha RX-V1600. I'm hoping the downward angle of the motorized drivers will help imaging on the bed.
The Panasonic will be wall mounted to the and pitched down slightly to allow easier viewing in the bed.
We'll use a hardwired IR retransmitter to eliminate lag in commands from my Harmony remote. The video signals will be delivered to the TV via a 25' 24ga HDMI cable from the RX-V1600.
I'm planning to expand in the future by wiring the receivers second zone outputs to the master and guest baths which will allow me to install some dipoles at a later date.
My viewing habbits in my bedroom are HDTV and TV series on DVD. For movies I have a dedicated home theater in my basement. So any input or suggestions would be appreciated.
DirecTV HR-20
Equipment List
Install
