Oh, I wasn't aware the AntiMode will not boost dips. That's useful to know. Similarly I also discovered that the parametric EQ on my sub (a SVS PB13) will only cut not boost.
So what EQs out there can do both cut and boost?
Or alternatively, if the AntiMode can cut the region between 16-44 Hz and bring it more in line with the rest that would work also right? Any guesses if the AntiMode algorithm would do that in my case?
Try moving the sub or seating around, sometimes 2 inches make a difference. Another option is bass trapping, youd be amazed at the difference they make.
That's what I hear a lot, movement of a few inches can make a big difference. In my case, I did some coarse movements first (i.e. moving the sub in increments of 12 inches sideways). In all positions there's still that dip around 40-80 Hz (though the shape and degree might vary a little). I might try a few more fine movements (increments of 3 inches) but I'm not hopeful of a lift in the 40-80 Hz region.
Can bass traps help? I was under the impression they can cut peaks but not boost dips.
