Hi guy's,
I just got my new pioneer 1120 with MCACC and after calibration my sub has a little to much boom. When adjusting the volume on sub or receiver it's ever to low or ton much boom. So was thinking about getting a SMS-1 or Antimode to help control the boom from the sub. Which one should I get to help me with this small problem. My sub is a 15" velodyne ct150. |
Flattened out my peaks, confirmed by REW.
Eliminated most of the boominess/ringing I was hearing.
Tightened up the mid bass.
I'm satisfied with results so far and the 8033 really is a "plug and play", easy to use device. Now if it could do something about my big 50hz null, like send subliminal messages to my wife so I could rearrange the room, I'd be pleased as punch...
I'm no longer using an Audyssey equipped receiver after sending the old one back (I'm using a Pioneer SC-27). It's very easy to recall them not being nearly as flat as I can get now, as well as the reduction in room nodes. This is with an average of three points across the main listening positions.
