AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Need advice on new remote: Bought refurbished Harmony 659 and hate it. Me or remote?
post #1 of 4
Previously, I had a cheap $15 remote from radio shack that controlled all the devices and worked perfectly. Unfortunately, it died and I had bought a new TV so figured it was time to upgrade to the next generation of remotes.
I own a new Panasonic Plasma TV (TH-42PX80U) to go with my old DVR Panasonic Showstopper PVHS2000 and Panasonic DVD-S27 DVD Player. This is in the bedroom and there is no surround sound or any other devices. Just these 3 devices.
I decided to try the Harmony 659 refurbished from Amazon for $49. I spoke to customer service and they were pretty good at getting it set up. But then I started experience problems: It wouldn't work consistently and the lag time was ridiculous for watching TV. Also, there wasn't an enter button if I was changing channels so I had to wait the 1-3 seconds when watching tv with a two digit channel number.
I want to get another remote.
My criteria:
1) Operate all 3 devices without a lag time.
2) Unit that has good layout of button design and lighting at night.
3) A remote with an enter key (although factory tv remote doesn't have one)
4) Easy setup.
What can you suggest for my new remote?
Why is everybody enamored with the logitech harmony? Was it just that I had a bad experience or is it that much better? Please help me understand.
Thanks in advance
Anthony
post #2 of 4
First, I would suggest you check out the first thread in this section, Harmony Slow Response. Most likely your lag issues can be fixed by adjusting your delay and repeat values.
Second, there is an enter button on the lower right side of the 659 next to the zero button. I would check to make sure that it is programmed as enter. However, if your original TV remote doesn't have an enter button, I doubt there will be one available for the Harmony, and if there is it might not work.
Third, have you tried 3 channel numbers to change channels. Sometimes by entering three numbers it will change faster. So for channel 9 enter 009, or 035 for channel 35.
I think that most of your problems with the Harmony can be solved pretty easily if you do a little more homework. However, it could be the fact that your remote is a refurb, and it might not be working correctly.
I wish you luck, and I hope you can get your issues solved. I know that I have become very happy with my Harmony remotes, as are everyone else who uses them at my house.
post #3 of 4
If you give up on the Harmony, you might like THIS one (HERE is a good picture of one). I got a couple of these myself from this seller and am very happy with them. They are new and have lots of codes, so would likely work fine with all your devices.
post #4 of 4
What do you mean by lag time? Is it from when you key in the channel to the remote (see Beer...) do a 3 digit channel number to get things faster (I know my old cable box had a setting to go right to the channel, or wait for the 'enter' button.)
Or is it that you tuner takes a while to switch to the new channel. If that, that the new 'feature' with digital tuners
Most newer universal remotes tend to, I really like my new Harmony One. I've upgraded from a 659--needed extra buttons to work my TiVo HD.
As the other poster noted, if the standard remote doesn't have one, you're likely out of luck, but, do check the preferences of your tuner box and see what other settings they have for changing channels.
4) Easy setup.
Anthony
As a Mac user Harmony is really the only game in town, but, each universal remote has it's good and bad points.
  Back to Forum: Remote Control Area
