AVS › AVS Forum › HDTV › HDTV Technical › D* HR20, have to choose between HD 2.1 vs SD with dolby 7.1 channels?
post #1 of 4
I sent a while searching...Can't seem to find the answer.
I have a DTV HR20 going through the new Onkyo TX SR 506 using HDMI cables. If I chose a HD channel I only get 2.1 or I can do the SD channel and get Dolby 7.1. Any ideas of what the problem could be?
post #2 of 4
If you have DD enabled on the HR20 and are watching a channel with 5.1 surround, you should be getting 5.1. You probably are switching to Pro-Logic on SD channels and the 506 is converting 2.0 to 7.1. Try the audio forums here for more assistance with the SR 506.
post #3 of 4
Ok, I will take your advice, thanks
post #4 of 4
I figured it out...Non SD channels are not dolby, meaning all five speakers are playing the same thing, lol...HD channels are dolby where the rears don't do as much...
  Back to Forum: HDTV Technical
