Originally Posted by nwiser
yeah its pretty annoying. right now its just affecting the analog channels...VHF as far as I can tell. I cant really be sure about the digital channels...as theres no way to check them with and without the box...the "signal" scales on the DT250 and my Insignia DTV are completely different.
VHF channels 2-6 are especially susceptible to this kind of interference. (This is one reason why most broadcasters have avoided using those channels for their digital signals.) From what you described below, it does sound like the interference is only happening in APT mode, so it probably doesn't affect digital reception. Still, you'll probably see less interference on analog channels 7 and higher. Of course that's no consolation if you need APT for one of the lower channels.
Two boxes with the same problem - makes me wonder if this was a bug in all the earlier models (sort of like the audio bug in the Zenith / Insignia). Mine doesn't seem to have the problem (analog channels 3 and 4 are both OK), so Apex may have fixed it in a later production run.
