AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Apex DT250 with passthrough
Apex DT250 with passthrough - Page 9
post #241 of 251
The poster above was right, I was using CNN as an example. KSTP channel 5 runs a news scroll along the bottom of the screen like CNN and part of it is cut off.
post #242 of 251
Originally Posted by jjeff View Post
WX+ is a very good channel to notice the overscan. I had a 250 so I'm not to sure how the 502 handles overscan. On my 250 I could not get rid of the overscan no matter what setting I used.
Originally Posted by systems2000 View Post
16:9 wouldn't get rid of the overscan? I've found that the Newshour sets their graphics to go off the screen on 4:3. It appears they are doing this with disregard to 4:3, since they are broadcasting in 16:9.
I sure wish the stations would get their "Auto-Aspect" settings correct.
WX+ is a 4:3 broadcast, so the aspect setting on the Apex can't be changed. If you try, you just get an error message; the overscan can't be eliminated.
On 16:9 broadcasts, the normal/letterbox setting will eliminate the (vertical) overscan (there's still some horizontal overscan but that's rarely a problem), but it still overscans on the fill or zoom settings. (On most TVs, anyway. A very few TVs can display the DT250's output without serious overscan; I'm lucky enough to have one.)
post #243 of 251
If overscan is a real problem but one wants to keep their DT-250, one could always adjust the vertical/horizontal size of the image via the Television's service menu or pots in the back.
post #244 of 251
Has anyone taken this apart yet? It looks like it has a lot of the same parts as the Tivax STB-T9. Maybe it'd be easier to put RS232 control in the DT250 than S-vid in the Tivax?
Anyone?
post #245 of 251
Why do you want RS-232? I believe they do have a header on the CB.
post #246 of 251
Well, for control, for one thing.. and of course for the thrill of unlocking an undocumented feature. =)
post #247 of 251
Hi I just got a Apex DT250a. It isnt one of my favorite boxes tested. When i go to add a channel manually. say 24 (ill use this as the virt and real # are the same) So i punch in 24.1 i get the picture, check signal strengh, Its good, i get channel info everything seems good, but it wont add it to the channel map. Doesnt seem to matter what channel i do this with. I can watch the channel, but its not in the channel lineup like it should be. Defective? just junky? Any advise? I still like my hisense 2010 the best so far.
thanks.
post #248 of 251
That's better than the tuners in Vizio tvs. Vizio won't allow any direct entry of RF channels at all. If you didn't scan it, you don't watch it at all!
post #249 of 251
A friend has one of these that is barely used, but out of warranty.
It won't power on. When it is unplugged the power light blinks red or orange.
Trash can it, or suggestions to try to revive it?
post #250 of 251
The light blinks red or orange when it's unplugged from the wall?
post #251 of 251
Yes, a few times, probably until the reserve power bleeds out.
