Apex DT250 Likes and Dislikes
(After living, eating and sleeping with my Apex for 2 ½ days)
Overall rating: VERY GOOD
disclaimer: I am very critical on my dislikes, and it is also my first ATSC experience
+Ability to disable sleep timer- a post on a different model made it sound like it was
not possible on that model (I can leave it on to record from when I leave home, but
limited to only 1 channel, and when I awake it is already on)
+Good Reception and PQ- See later updates for overscan problems
+S-video- Probably not needed for better PQ, but offers better flexibility in hookup
+APT- no signal loss, but this box works so well I don’t need APT, all my stations are
already ATSC
+Smart Antenna Capability- I read this is like an automatic rotor for each channel
+Variable audio out (RCA)- No need to switch to another remote or mode
+Zoom settings are remembered for each channel but can only be set if aspect ratio is
NOT set on auto. Setting it in my 4:3 mode, then switching aspect ratio back to auto
still remembers zoom settings (also see aspect ratio dislikes below)
+Audio Quality- Initial problems were the result of using an old faulty cable and other
equipment settings -I SHOULD HAVE USED THE NEW SUPPLIED RCA CABLE IN
THE BEGINNING
+No overheating- after being on about 2 days box bottom is approx 110
+No bulky DC adapter cord
+AND THE NUMBER ONE AND ONLY COMPARISON TO OTHER CECB’s- I only
had to wait about 28 days before available and in stock!!! (Drrr-rumPP-CHING)
Neutral likes (could be better but still acceptable or doesn’t really matter)
+Remote and menu ergonomics- this moves to the better as I get used to it, but will
never make it to likes because I know it could have been improved with more
development (My biggest dislike: Favorites are accidentally changed because fav
add/del button is next to fav surfing buttons)
Dislikes:
-Auto aspect ratio- does not seem to do anything on my 4:3 except prevent zoom
function, and seems only useful if a person is clueless whether to use 4:3 or 16:9
This auto setting confuses things and is probably the basis of some windowboxing
complaints (not to be confused with letterboxing) Auto zoom when appropriate would
be a much more useful feature. But, at least the box remembers your last zoom
setting for each channel (also see zoom setting in likes above)
-Inability to add single channels to the scanned (viewable) list- I believe this might
make it difficult to turn a directional antenna and get additional channels for stations
in different directions.
Maybe using a smart antenna would solve this problem. Could be a bigger problem on
requirements of a directional antenna in more difficult reception areas, but not so bad
on my $60 amplified omni-directional about 30mi from towers in mostly same direction.
-I’m still uncertain how to delete scanned channels or if there is a need to- Scanned
channels can just be marked as unviewable. Rescanning will delete if reception
is not present for that channel. The only way I was able to delete channels was to
rescan without an antenna. (and the only channel it picked up was still that darn
shopping channel) Doing a reset or unplugging does not change the scanned list,
it only changes the "not viewable" and "fav" attributes or markings
-AND THE NUMBER ONE DISLIKE ABOUT THE DT250: It does not do the dishes
or set the recorder!!! (Drrr-rumPP-CHING) I gotta go, my NTSC box is getting jealous.
Revised: Another plus for the remote is excellent wide angle transmission
