AVS › AVS Forum › Audio › Speakers › looking for a skinny center channel
post #1 of 5
I see there are many threads about this, but my setup requires a skinny center channel speaker. My tv is on a fireplace mantle with bricks behind it, so I can't wall mount it, and the stand of the tv takes up most of the shelf space. If I could find a skinny speaker, I think that would work for me.
Waddya think?
post #2 of 5
I would recommend matching your center channel with your existing speakers. If you don't, your sound quality will suffer.
You could always make a small wooden plate that sits under your tv and attached your center channel mount to it. Your center channel would then hang over the edge of the mantle. Of course, if you use this fireplace, you could always choose to suspend the center channel from the ceiling.
post #3 of 5
If I was forced to use a puny little center channel, I would just run without one...
post #4 of 5
+1
post #5 of 5
Skinny enough for ya?
http://store.audioholics.com/search?...n-wall&x=0&y=0
Also these which I have, and have been pleased with:
http://emptek.com/EMPOn-linestore/ca...97c6e23c08ac4a
  Back to Forum: Speakers
