Summary
I have experience with only two converter boxes: a Channel Master CM-7000 and a DigitalStream DTX9950. This is a comparative review.
The CM-7000, when hooked up with the S-Video connection, has superior picture quality.
The DTX9950 is superior in almost every other way.
Comparison
Overall the DTX9950 is a more refined product, you can tell the moment it comes out of the box. It has larger and more clear fonts for the onscreen menus. The menus are more logical, and offer more control. Initial setup is easier. The box gets less warm in use, and is "Energy Star" certified. In standby, the DTX9950 uses a fraction of the energy. There is more control over fonts and colors on closed captions. The manual is much clearer and refined. The unit is physically smaller, and frankly looks better. Reception quality is better, in my area I get two more channels without digital artifacts, using the DTX9950. The "signal strength meter" is much better, with a nice red/yellow/green indication of signal quality (the CM7000 by contrast claims just about every channel comes in at "100%").
Deciding Advantages
The big advantage of the DTX9950 is in the remote control: it controls not only the converter box, but your TV. This means for most common functions you don't need to juggle two remotes. Specifically: it controls TV Power, TV Input Source, and TV Volume (just what you need!).
The big advantage of The CM-7000 is picture quality. Without the S-Video connection you get a grainy appearance, akin to poor analog reception. You get color bands (called "Morrie patterns") that crawl across people's faces. Hooking the CM-7000 up with S-Video clears all this up, resulting in clean vibrant colors and natural skin tones.
Comparison
Deciding Advantages
